03-06-2018, 12:29 PM | #1 |
Liked 53 Times in 20 Posts
Beadlock Conversion
Has anyone had any experience with converting there wheels to beadlocks there are single and double conversions available. I know it adds weight but not that much they have it down to about 3.3 lbs per single lock. The tire has moved about 1 inch in 1-2 events
03-06-2018, 01:29 PM | #2 |
Re: Beadlock Conversion
Weld Wheel did me Magnums. quick turnaround
03-06-2018, 02:25 PM | #3 |
Liked 389 Times in 168 Posts
I always put a mark on the tires by the valve stem. Mine have always moved some at first. Have always stopped moving by the second race. Tubeless, 13 psi. Learned to not lube beads when mounting. Just mount dry.
Ed Wright 4156 SS/JA |
03-06-2018, 05:18 PM | #4 |
Liked 463 Times in 134 Posts
Champion Beadlock does good work and they are fast! I've never seen one move on a single Beadlock yet .
5664 AA/SA 1970 NOVA |
03-06-2018, 07:26 PM | #5 |
Liked 133 Times in 49 Posts
Holeshot Wheels in Bunnell, FL does their own as well as other brands.
https://holeshotwheels.com/collections/beadlocks My tires have moved also, but less over time. I also swap them side-to-side after every race to minimize any change in balance and tread wear.
LOCOMOTION Racing |
03-08-2018, 03:02 AM | #6 |
Liked 665 Times in 258 Posts
Frank Parks does it, too!
Adger Smith (Former SS) |
03-08-2018, 11:15 AM | #7 |
Liked 220 Times in 95 Posts
What's the difference between single and double?
Floyd Staggs 787 SST |
03-08-2018, 11:45 AM | #8 |
03-08-2018, 12:36 PM | #9 |
I know that but is there any difference in the way they perform? Do you need the clamping on both sides? I've always used screws but I just got new wheels and I don't want to drill them.
03-08-2018, 06:11 PM | #10 |
On my last set from Larry Hodge we bead locked the front and knurled the rear so they won't go anywhere. I don't see any way the back can move on a single ,but I'm not running the horsepower to worry about it. Big hp guys probably need double's.
