Old 02-08-2018, 09:32 PM   #11
Ed Wright
Ed Wright's Avatar
Liked 389 Times in 168 Posts
Default Re: Clutch Switch
[QUOTE=Rod Greene;555556]
Some Stockers have a switch on the brake pedal for their 2step.[/QUO
That would be quite feat. 3 pedals at once.
I said "some", that would not be a stick car. I think you knew that. LOL
Ed Wright 4156 SS/JA
Old 02-08-2018, 11:06 PM   #12
Don Fardie
Don Fardie's Avatar
Originally Posted by Rod Greene View Post
I went on the BIONDO web site couldn't find the switch. Do you have a part number?
Thanks, Rod
I believe it was a Biondo Transbrake switch, but here is a link to the Jegs version. As far as adjusting it when clutch set up is being changed it's easily corrected to account for any rounds being added or removed.....and that is if any adjustment is really even needed. Good Luck!!
http://www.jegs.com/i/JEGS-Performan...10353/10002/-1
Don Fardie 1582 F/S B/G
Don Fardie is offline   Reply With Quote
Old 02-11-2018, 05:52 PM   #13
Wayne Totaro
Liked 38 Times in 12 Posts
Rod, I use the Biondo switch. I drilled a hole in my clutch pedal and the switch comes through the hole! When my foot is on the clutch it is activated! Works fine!
J. Wayne Totaro 1117 STK
Wayne Totaro is offline   Reply With Quote
Old 02-11-2018, 09:08 PM   #14
T Ames
T Ames's Avatar
Liked 88 Times in 28 Posts
Rod,
I use an OMRON switch P/N D4C-1620 (actuated by the clutch fork). It looks very similar to the Jerry Bickel switch, but it can be found on ebay for ~$15 new.
Tim
T Ames is offline   Reply With Quote
Old 02-12-2018, 01:25 PM   #15
CMcAllister
Liked 745 Times in 206 Posts
Don's setup looks pretty nice.
I may have to try that on my next clutch job !
I've used the Jerry Bickel switch in the past which is a very heavy duty switch with molded in leads and an adjustable arm .
they also have a universal mounting bracket for it.
I've put these on a number of stick cars for guys. Fab a mounting bracket and a tab on the pedal to actuate it. Infinitely adjustable. Guys like them fine.
CMcAllister is online now   Reply With Quote
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Copyright © Class Racer.com. All Rights Reserved. Designated trademarks and brands are the property of their respective owners.
