HOME MAGAZINE FORUM RULES SPONSORS CONTACT
Old 02-07-2018, 07:32 AM   #11
Billy Nees
Liked 87 Times in 45 Posts
Default Re: Cam&Lifter& valvelash?
You not only lose lift. You lose duration too, and more than you would think.
Billy Nees 1188 STK
Billy Nees is online now   Reply With Quote
Old 02-07-2018, 08:37 AM   #12
Alan Nyhus
Liked 3 Times in 1 Post
Thumbs up Re: Cam&Lifter& valvelash?
Originally Posted by MikeMoller View Post
Wondering about the loss of lift running solid lifter. If you have to run lash but the cam is checked at zero lash by NHRA then you would have to lose some lift using solids.
Yep. Keeping as much lift and duration as you can is the key. Very tight valve lash addresses this. That's not a blanket recommendation, just a mechanical fact.
Question is, do you lose lift with a hydraulic lifter at zero lash or with some preload, and how much?
Even with a true hydraulic lifter full of oil, there will be some amount of push rod cup movement (down) as it acts against the valve spring. How much is the question and depends on a lot of things.
Then is a solid lifter really the way to go?
Maybe. Maybe not.
Good discussion. -Al
"That'll never work....."
Old 02-07-2018, 09:51 AM   #13
Pat6868
Treated cam, tool steel hydraulics plugged at .008, lash them where you like.
Pat6868 is offline   Reply With Quote
Old 02-11-2018, 05:18 PM   #14
GTX JOHN
Liked 9 Times in 8 Posts
I absolutely agree with both Derek and Alan.
MY boy will be testing the solids in his combo.....I will let you know
how it ends up!
John Irving
741 Stock
741 Super Stock
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
Copyright © Class Racer.com. All Rights Reserved. Designated trademarks and brands are the property of their respective owners.Ad Management plugin by RedTyger
