HOME MAGAZINE FORUM RULES SPONSORS CONTACT
Old 02-04-2018, 06:27 PM   #1
J.R. Haddad
Liked 2 Times in 1 Post
Talking How much oil?
How much oil should a Metric 200 with a Turbo Action
deep pan hold. Thanks.
J.R. Haddad is offline   Reply With Quote
Old 02-04-2018, 07:15 PM   #2
Ed Wright
Ed Wright's Avatar
Liked 50 Times in 20 Posts
Default Re: How much oil?
Why not call Turbo Action?
Ed Wright 4156 SS/JA
Old 02-04-2018, 07:17 PM   #3
J.R. Haddad
Their closed on Sundays. LOL.
Old 02-04-2018, 08:29 PM   #4
jimmyparker
Liked 10 Times in 4 Posts
If you are starting with a new trans and convertor 7 quarts is a good place to start, you don't want to overfill a 200.
jimmyparker is offline   Reply With Quote
Old 02-04-2018, 08:32 PM   #5
J.R. Haddad
Thanks Jimmy.
Old 02-04-2018, 10:27 PM   #6
MR DERBY CITY
Liked 41 Times in 15 Posts
Just curious, do you not have a dipstick ?
Old 02-04-2018, 10:56 PM   #7
Kevin Love
Go to Turbo Action's website-there is a tech bulletin outlining fluid levels for metric 200s
Kevin Love 5666 SS
Kevin Love is offline   Reply With Quote
Old 02-04-2018, 11:23 PM   #8
J.R. Haddad
Yes M.J. I have a dipstick, but it is a Lokar and they are tough to read
the same day you put oil in them. I just wanted some other opinions
to get it close when I fired it up. Tough crowd tonight.
Old 02-04-2018, 11:40 PM   #9
ss3011
ss3011's Avatar
Liked 5 Times in 3 Posts
It's important that you check the calibration of your dipstick . With a stock pan the " Full Hot" line should be at the same level as the pan gasket . Keep in mind that Full Hot means the fluid is at 200 degF . The factory dipstick also has a min line which is at the bottom of the cross hatch marks . The min line is a full mark at 70 degF. You want to make sure the fluid level never exceeds the Full Hot line , because if the Fluid gets up into the rotating parts , it will froth up like a milkshake . This will cause all kinds of problems , the worst being oil out the breather which, if it gets on hot parts , could cause a fire .
Old 02-05-2018, 08:55 AM   #10
Mike Pearson
Mike Pearson's Avatar
Liked 14 Times in 8 Posts
If it has an extended pick up on it then you don't need anymore fluid than with the stock pan.
Mike Pearson 2485 SS
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
Copyright © Class Racer.com. All Rights Reserved. Designated trademarks and brands are the property of their respective owners.Ad Management plugin by RedTyger
