Old 02-02-2018, 06:36 AM   #1
jimi
Liked 21 Times in 8 Posts
Default Avenger super stock , modified,gt bracket car etc....
1997 S/S DODGE AVENGER ,GT,MODIFIED , X CLASSES, SUPER CLASSES, INDEX CLASSES ,PRO STREET CAR.
http://s32.photobucket.com/user/jarn...roir1.jpg.html
$26,000 complete car, will separate. Trades considered.
You will not find a better built or better quality component car anywhere. The price is a steal “MOTIVATED” just want it gone!!!!
ENGINE , 300” W8-R3
The engine is 300ci. W8 R3. It has cfe heads and intake. Holly 700 cfm dual carbs. 2.200”titanium intake 1.55” exhaust 380 cfm @26” water on super flow 600 flow bench. Flow clean to .850” lift T&d rocker gear. 1.65 ratio. Bullet cam ,.850”. Winberg billet 2.900” stroke crank X 4.080” bore. Block can go to 4.175” bore block is Siamese bore. 8.900” deck ht. 50 mm roller cam bearings. Groden Rods JE pistons 15.1 to 1. Weber belt drive. Ft mount distributor. Ati balancer with trigger built in Stock car products belt drive oil pump. Charles pan. Stainless step tube tri y headers. Moroso sheetmetal valve covers.
Engine is out and apart for parts verification and viewing.
TRANSMISSION,
A-1 proflite 2.39-1.5-1.0 clean neutral 7” negative blade tc ,trans is fresh.
REAR DIFFERENTIAL,
chromoly sheetmetal ford 9" rear , strange 40 spline gun drilled 300m axles.
BRAKES,
wilwood dual rear caliper brake set up,wilwood front disc brakes,all stainless steel hard lines. chrysler big bore aluminum master cylinder, custom ratio aluminum brake pedal, dot 5 synthetic fluid.
SUSPENSION,
santhuff front struts, rear coil overs, both double adjustable, Chris Alston avenger 4 link, splined anti roll bar, wish bone locater, lower dodge viper front controll arms.
CHASSIS ,
Alston/Half Scale chromoly chassis, built like a tube car in a stock uncut
body, car is certified to 8.50 , would need minor updates to exceed the 8.50 spec.(front gussets,funny car cage addition)car is fitted to accept large driver, 6' 300#, has driver side swing out bar.
INTERIOR,
full stock interior, two seats , full carpet, stock dash board, dash removes in 5 minutes, both power windows operate, all stock glass no lexan.
BODY,
complete stock body except for fiberglass hood. beautiful all black paint, has small dent above driver door. stock location fire wall, stock location factory front frame rails and fender wells, this engine bay has a ton of room for any engine.
RIMS /TIRES
weld wheels , hoosier tires, no tubes.
CONTACT,
James Vignogna 845-298-9041 jarn05@msn.com photobucket
Edited by Jimi_Vignogna (02/02/18 05:27 AM)
Old 02-05-2018, 11:19 PM   #2
Chris Hill
Liked 238 Times in 25 Posts
Default Re: Avenger super stock , modified,gt bracket car etc....
Will this car run as a GT superstocker without issue?
Chris Hill
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Copyright © Class Racer.com. All Rights Reserved. Designated trademarks and brands are the property of their respective owners.
