Old 07-24-2017, 12:31 PM   #1
drgrcr1156
Liked 2 Times in 1 Post
Default Racepak short record
I have a Racepak sportsman that would not complete recording most of the run last year. On occasion I would get a complete record. Racepack could not explain the issue except possible EMI interference. I replaced plug wires and the Racepak SD card this year and I started getting complete recordings. Problem solved? This past weekend, out of 5 runs, two were not complete. Anyone experience this same issue?
Bob
drgrcr1156 is offline   Reply With Quote
Old 07-24-2017, 08:48 PM   #2
jim hensley
Default Re: Racepak short record
are you shutting off the power to kill the engine at the end of the run?
jim hensley is offline   Reply With Quote
Old 07-25-2017, 12:22 PM   #3
drgrcr1156
No, The power is on until half way down return road.
Bob
Old 07-31-2017, 06:00 PM   #4
voltdr
Liked 87 Times in 47 Posts
Are the incomplete runs missing the beginning or the end of the run?
Dan
voltdr is offline   Reply With Quote
Old 08-01-2017, 12:31 PM   #5
drgrcr1156
The incomplete runs are missing the end of the run.
Bob
Old 08-03-2017, 05:02 PM   #6
voltdr
Double check that the record time didn't get reset to a shorter amount of time. Also, when do you start your recording? during the burnout or just before the staging?
Dan
Old 08-04-2017, 12:26 PM   #7
drgrcr1156
Have checked the record time and it has not changed. I Start recording just before staging. So far about 50% of my recordings have been short and not by the same amount. I compared the MB amounts.
Bob
Old 08-04-2017, 05:10 PM   #8
voltdr
Does the logger voltage also stop at the same time as the RPM stuff? If so, that means that the logger is losing power at that point. Where are you getting the power for the logger? Main battery switch, separate switch????? Does the recording stop at the same time on each of the incomplete runs?
Dan
Old 08-07-2017, 12:28 PM   #9
drgrcr1156
I get the logger power off of the ignition on switch. The recordings do not stop at the same place. I check the file details for the size of the file and they are different. I check this to rule out the time I start the recording as different.
Bob
Old 08-08-2017, 09:05 AM   #10
voltdr
Are you saying that the ignition switch powers the logger or a switch that gets it's power from the ignition switch?
Dan
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Copyright © Class Racer.com. All Rights Reserved. Designated trademarks and brands are the property of their respective owners.
