Old 04-14-2017, 07:56 AM   #1
Chris1529
Liked 57 Times in 27 Posts
Default Bias vs Radial slick
I have 28 x 9 M/T Bias slicks on my car right now. If I switch to a 28" Radial, can I expect much finish line RPM difference? Anyone have any finish line RPM info they can share when switching from Bias to Radial on the same size advertised tire on?
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 05-08-2017, 12:15 AM   #2
LemonWedge
Default Re: Bias vs Radial slick
The 28x9 MT ET Drags measure 27-1/2" according to MT. Depending on how fast you are, it likely grows to 28" or even a little beyond. A radial won't grow. So if the radial you're looking at is exactly 28", you likely won't see much change in stripe RPM.
The key here is that bias tires grow while radials do not.
LemonWedge is offline   Reply With Quote
Old 05-12-2017, 09:53 PM   #3
Mike Rietow
Mike Rietow's Avatar
Liked 30 Times in 16 Posts
The bias has high energy losses at all frequencies (deformation). The Radial will have low energy loss at low frequency which means less resistance to roll. Less rolling resistance means more mph. More mph requires more rpm. How much more rpm? ... How much more mph?
Mike Rietow is offline   Reply With Quote
Old 08-14-2018, 12:45 AM   #4
LemonWedge
I just went from an MT 28x9 ET Drag slick to a 28x9 Pro Bracket Radial. I’ve only made a couple of passes, so results are purely preliminary; but it would appear I picked up roughly 1 mph and perhaps as much as a tenth. Didn’t notice any real change in stripe RPM, but I only had 1 hit then dial.... 1st round I chopped a couple at the stripe, so the jury is still out. My sense is no real change in effective gearing.
I’ll check back in here after I have some reliable data.
Old 08-15-2018, 10:27 AM   #5
Chris1529
Thanks for the info. I haven't purchased any new 28" tires yet to try.
Chris Bowman
1984 Mustang GT350
Old 08-31-2018, 12:18 AM   #6
LemonWedge
I’ve got more than a handful of passes on them now. Maybe 200 RPM increase at the stripe. I’m very happy with the initial results I’ve seen from these PBR’s.
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Copyright © Class Racer.com. All Rights Reserved. Designated trademarks and brands are the property of their respective owners.
