Old 02-20-2017, 07:51 PM   #11
Hacksaw
Liked 276 Times in 151 Posts
Default Re: Powerglide first gear
Originally Posted by Lenny5160 View Post
My Super Street car weighs 3575# and runs a 1.80 glide with 4.30 rear gears. I have more power but because of the weight I am only a little quicker on ET. Runs right around 10.30 wide open and goes 10.90 at about 127.
With a Pro Tree transbrake I am leaving at 3800 RPM with .050-.060 in the box, so no problem cutting a light.
With these kinds of numbers, I think you must be running a BB. ?
Old 02-20-2017, 09:34 PM   #12
Marty Hignight
Liked 22 Times in 13 Posts
Thank you for the advice guys, seems a majority is to keep the C4 - this does save me some money to spend elsewhere.
Marty
Marty H
Marty Hignight is offline   Reply With Quote
Old 02-21-2017, 11:25 AM   #13
Lenny5160
Lenny5160's Avatar
Liked 432 Times in 225 Posts
Yep, 468 BBC on alcohol. I figure it is just a little under 700 hp.
S/ST 51
S/C 53
Old 02-23-2017, 04:54 PM   #14
Stirk18
I'd stay with the C4 with the power level you have , No problem hitting the .500 tree with that combo.
I have several Super Street customers who run 3 speed transmissions because their car is a heavy weight .
If it was my car ,I'd keep the C4.
If you dont mind me asking, how are you approaching the Stop set-up with the 3 speeds? Are you running t stop in 1st gear or 2nd gear? How low in the run is the stop coming on for them?
Have a friend who may dabble in this who runs a heavy S/P car (SBC) with a Flying toilet injection system and a 3 speed. Runs 10.60's in 1/4 at 123. We dont run 3 speeds s I'm curious what others are doing with them and the stop?
Thanks,
Andrew
Stirk18 is offline   Reply With Quote
Old 03-03-2017, 08:01 AM   #15
Robbie Welch
Liked 262 Times in 124 Posts
I'm on the stop at 020 and its on for usually between 1.70 to 2.10 then it shifts into second. My car runs 10.teens usually. I here that toilets have to be shut back to idle to work well?
Old 06-19-2017, 10:11 AM   #16
SmBlkFord
Sorry to high jack the thread, but has anyone ever experienced a much slower rollout when swapping first gear in a powerglide ? Say 1.98 to 1.80 . Thanks guys
SmBlkFord is offline   Reply With Quote
Old 06-19-2017, 11:02 AM   #17
Jeff Stout
Liked 655 Times in 255 Posts
To bad I'm in AZ I have a B&M 1.98 glide ,w/brake. Bell housing cracked and welded. Install and dedenbear bell housing and your set. $900 plus shipping which wouldn't make it feasible.
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Copyright © Class Racer.com. All Rights Reserved. Designated trademarks and brands are the property of their respective owners.
