HOME MAGAZINE FORUM RULES SPONSORS CONTACT
Old 01-11-2017, 10:53 AM   #11
Lenny5160
Lenny5160's Avatar
Default Re: Separate back up button?
Originally Posted by voltdr View Post
If you use a toggle switch, you won't forget that it's on. As soon as you put the trans in low gear, to move forward, the brake will be applied. Then you know you have to turn off the switch.
Dan
That's fine until you back into your parking spot and then shut the ignition off.
My preference would be to avoid ANY possibility of forgetting, bumping the switch, etc and burning up the solenoid.
Tony Leonard
S/ST 5160
S/C 5160
Old 01-11-2017, 10:39 PM   #12
voltdr
Wire it so it is only active when the ignition is ON.
voltdr is offline   Reply With Quote
Old 01-13-2017, 10:18 PM   #13
Bill Baer
Your right! I would be putting power to the output side of an open relay.
Duh
Thanks Voltdr.
Thanks for the advice guys.
I think I'll just use a momentary toggle switch on the dash.
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
Copyright © Class Racer.com. All Rights Reserved. Designated trademarks and brands are the property of their respective owners.Ad Management plugin by RedTyger
