HOME MAGAZINE FORUM RULES SPONSORS CONTACT
Old 12-02-2017, 06:55 PM   #61
J&S Racing
Liked 9 Times in 2 Posts
Default Re: 69 Camaro B/S
Originally Posted by Bob Gullett View Post
http://www.swracecars.com/store/Seat...36=95-379.aspx
I have these on my car from S&W racecars.
I have a pair of these now.
Old 12-02-2017, 09:15 PM   #62
Nmbr1GMfan
Liked 2 Times in 2 Posts
A friend of mine cut the mounts about 1 inch above the bottom mounting flange and welded them to the bottom of the Kirkey, then bolted the flange to a seat track.
Todd Greene
Old 03-07-2018, 06:39 PM   #63
J&S Racing
While we're waiting on Todd to get out of paint shop prison I'll get a update in..
Seats are in.
I started fitting the interior.... The gauge cluster turned into a nightmare with the dash bar but after quite the modifications I was able to get it fit. Looks like the K&R switch panel is gonna fit nice in the radio spot .
I ended up going with Aeromotive for the entire fuel system.
Hopefully the weather breaks so I can roll it outside and paint the trunk and dash. Until then the radiator is ordered and on its way.
Old 03-08-2018, 06:47 AM   #64
Robert Simpson
How wide are your kirkey seats? Did you have to make a custom bracket to attach them to the floor? Do you have any pictures? Thank You
Robert Simpson is offline   Reply With Quote
Old 03-08-2018, 07:23 AM   #65
J&S Racing
17" wide. Ended up using 2X2 aluminum. Had to offset the bolt holes for the floor but it all worked.
The brackets bolted to the seat came from S&W. You should be able to get the idea from the pic I posted but I'll try to get a better one.
For what it's worth Rhodes race cars sells a nice bracket that bolts to the floor then bolt the seat to it but there like 150 each side.
Old 04-06-2018, 10:01 AM   #66
Nmbr1GMfan
I need to drive up to ART and get some of those carbon bar protectors. I also like the Aeromotive in-tank A1000. Coming together nicely!
Todd Greene
Old 04-06-2018, 06:18 PM   #67
J&S Racing
Thanks Todd.
Radiators in. Champion was great to work with and charged $100 to add the an fittings. I have to redo the top hose. What's that saying, measure twice cut once lol
The clown that did the cage talked me into letting him build a wheelie bar. What a total POS!!!!! It was 10" to long, un sprung and so crooked and weak I probably would've wrecked if it hit.
Anyone in the new England area stay far away from Steve Oldham and Top Notch chassis prison in Freetown MA.
I gave Ken Keir a call and he got me situated. What a super nice piece, night and day from the $700 junk I was left with.
Old 04-06-2018, 06:20 PM   #68
J&S Racing
Lightbulb Re: 69 Camaro B/S
Old 04-06-2018, 11:14 PM   #69
Nmbr1GMfan
Thinking about the AutoPlumb adapters for the radiator so I don't have to mess with welding to the radiator.
https://autoplumb.com/collections/au...mostat-housing
Sent you a PM about the bars.
Todd Greene
Old 04-07-2018, 01:25 AM   #70
J&S Racing
I saw the adapters but figured it was just another place to leak or have a problem. For the extra 100 I felt it was well worth it.. think I have 6 change into the rad, fans, shroud and fittings.....I set out to way over build the car in case I wanna go a different route some day but most importantly I want to lessen any chance of problems so I can drive it like I stole it...
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
Copyright © Class Racer.com. All Rights Reserved. Designated trademarks and brands are the property of their respective owners.Ad Management plugin by RedTyger
