Old 12-01-2016, 02:50 AM   #21
RON NICKELS
Default Re: Lazy off the line
Let me know when you find that spot on the tree,lol.
HAMMER
RON NICKELS is offline   Reply With Quote
Old 03-03-2017, 11:59 AM   #22
n5ifi
Not enough rear gear. Carb is too big. Cam needs to be advanced not retarded. That is killing the low end. Fix all of that stuff and it will run much better.
Exactly.......
putting the cam in 2 retarded is going to guarantee you more retard running.
I remember Joe Sherman always telling everyone that you could run the intake clearance very close just spinning the motor around by hand. If it clears by .010 to .020 it will be fine running because the dynamic loading of the system would increase the clearances and retard the cam. The valve is chasing the piston down the hole too.
n5ifi is offline   Reply With Quote
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Copyright © Class Racer.com. All Rights Reserved. Designated trademarks and brands are the property of their respective owners.
