Old 09-24-2015, 09:16 PM   #11
RobbieRacer
RobbieRacer's Avatar
Liked 116 Times in 40 Posts
Default Re: 79 Mustang project U/SA
Busy day today. Pulled the motor, trans, exhaust, and fuel tank. The junk pile is growing!
Old 09-24-2015, 11:00 PM   #12
black88coupe
black88coupe's Avatar
Liked 19 Times in 12 Posts
Cool!
Mitch Beri- The Motor City
Old 09-25-2015, 08:02 AM   #13
Old 10-16-2015, 10:37 AM   #14
goinbroke2
Liked 174 Times in 60 Posts
Thumbs up Re: 79 Mustang project U/SA
Update, pictures, anything....please!
Love this build, was supposed to start the same build a year ago and...it's still sitting...
Living vicariously through others so give an update please
Old 10-16-2015, 07:36 PM   #15
Kent
Kent's Avatar
Amen. Give us something!
Kent is offline   Reply With Quote
Old 10-18-2015, 12:14 PM   #16
RobbieRacer
Just cleaning up a few things and made a dump run to get rid of junk parts. I may have a buyer for my bracket car! If it sells it will be full speed ahead.
Old 10-26-2015, 09:20 AM   #17
RobbieRacer
Well got some bad news this weekend. The buyer for my 67 backed out. So this will be a slow build but I will get it done. I'll post as I get things done.
Old 11-27-2015, 11:22 AM   #18
RobbieRacer
Ok guys, i need some help. What is the best way to remove the door bars? I got no clue.
Old 11-27-2015, 12:35 PM   #19
Liked 4,447 Times in 1,693 Posts
I guess you can ask that here, seeing nobody else has them either.
Best way I've found is to take the door off and lay it on saw horses.
You cut the out the section of the jamb where the bar is spot welded with a thin cut off wheel , front and back.
Then you slide the bar out ,with the jamb pieces attached.
Separate the bar from the sheet metal pieces and then tack weld the pieces back in where they were.
Continue tacking until almost a solid weld, then grind and spot putty the jambs..
On some cars, you can drill the spot welds out on one end and not have to cut a window on both ends.
Once the bars are out, make sure the door shell is not able to be twisted.
In that case , weld the corners of the skin to the frame or brace accordingly.
Those door beams add quite a bit of structure to some models.
Call me if you need to..
MY
We are lucky we don't get as much Government as we pay for..... Will Rogers
Old 11-27-2015, 02:44 PM   #20
B/S 428
Liked 107 Times in 23 Posts
I would suggest removing all of the easy stuff first because it will be light for U/SA 3030 lbs. I have a 79 U/SA mustang Ghia with the standard easy stuff removed-heater box-wiper stuff and with a 200 lb. driver, I have to add 50-75 lbs. Brian
B/S 428 is offline   Reply With Quote
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Copyright © Class Racer.com. All Rights Reserved. Designated trademarks and brands are the property of their respective owners.
