Liked 11 Times in 5 Posts
G,day,
Just bought a new strange alloy pro hd case and pinion support, strange internals and Richmond 4.56 gears. Is there an instruction sheet available that gives pinion support tensions and main cap tensions? car is 3100 lbs, just dips into the 9's, footbraked at present but will put a tbrake in it at the end of the year, Have heard with the alloy case you tighten up a bit backlash wise? Any experience with these out there and what recommendations set up wise? Thanks very much! Paul |
