HOME MAGAZINE FORUM RULES SPONSORS CONTACT
Go Back   CLASS RACER FORUM > Class Racer Forums > Competition Tech
Old 11-30-2013, 04:58 PM   #1
Tony Curcio
Tony Curcio's Avatar
Default Should four-valve per cylinder V-8s and V-6s be allowed in
The OEMs have recently been producing some interesting V-8 and V-6 engines with features like 4-valves per cylinder, dual overhead cams with variable valve timing, and direct injection. But the rules for Altered and Gas Dragster classes only allow 2 valve heads, except in select 4 cylinder classes.
Id like to hear the pros and cons of allowing 4-valve engines in the existing classes, perhaps with a weight penalty. I think if they were allowed, some new entries would gradually appear, the speeds and rpm would increase, and maybe even some factory support such as there is now in stock & supper stock.
I can also understand how someone who has invested a lot of their personal resources in a current combination would be unhappy.
Any thoughts?
Tony Curcio 1860 STK
Tony Curcio is offline   Reply With Quote
Old 12-13-2013, 07:55 AM   #2
MICROMACHINE72
Default Re: Should four-valve per cylinder V-8s and V-6s be allowe
I think so, with added classes for them. I don't think 4-valve should be mixed with 2-valve existing classes in comp. They have g/ed, what not add another 4 valve class?
MICROMACHINE72 is offline   Reply With Quote
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
Copyright Class Racer.com. All Rights Reserved. Designated trademarks and brands are the property of their respective owners.Ad Management plugin by RedTyger
