Old 09-23-2009, 06:14 PM   #1
Tim H
Tim H's Avatar
Liked 481 Times in 158 Posts
Default Alcohol question
For the race car , not to drink. What might the difference be between Racing alcohol from a supplier such as VP versus Methyl Alcohol I can buy from my local Napa store ? Considering switching from gas to alky for next project.
Old 09-27-2009, 11:35 AM   #2
Alan Kenny
Smile Re: Alcohol question
Tim,
I believe the Napa stuff is Methyl Hydrate which has water in it and not good for racing. You need to run pure Methanol or Ethanol for racing with NO water. Methanol is available from chemical companies as well as VP. The VP stuff is more expensive but comes in lined drums and is always absolutely clean. We never had an issue with VP alcohol.
We used VP M1 and added the additive (M2? I believe). The newer alcohols M5? is more expensive and makes more power but I have heard it can affect fuel pumps and carbs. . . I would stick to the M1 and use the additive.
Al Kenny
Alan Kenny is offline   Reply With Quote
Old 09-28-2009, 08:08 PM   #3
Bill Baer
Default Re: Alcohol question
Tim
Al's right Methanol is what you want to use, I have used both VP and the stuff from the local chemical company and haven't noticed a difference except price.
There are a couple of things to consider while it's half the cost of racing gas you will use twice as much. It's a great solvent and will attack any un-anodized aluminum and some rubber hoses. your fuel system (pump and lines) needs to deliver more fuel.
You need to have bronze valve guides as the methanol will wash the oil off of them and the cast iron ones don't last too long.
I also run scented top oil (lube) for valve guide life and because it doesn't smell great.
I have always run it with one of Ron's fuel Injection systems they are simple and offer instant throttle response I have seen good and bad in alchol carbs.
It will make the car vary less with weather changes (more consistent)and with fuel injection the car will be a little faster but it will be harder to start especially if the temperature drops below ~60F.and it will take longer to heat up and if you don't have a vacumn pump the oil will look like snot and need to be changed more frequently.
Sincerely
Old 09-29-2009, 05:45 PM   #4
Tim H
Tim H's Avatar
Thanks Al and Bill for the info. There is more to making a successful switch from race gas than I initially thought. I have all winter to prepare.
Old 09-30-2009, 12:43 PM   #5
Steves68Nova
Steves68Nova's Avatar
Is it true you have to remove the foam from your fuel cell because the alcohol dissolves it? Someone told me that and I had never heard that before. I have thought about changing myself.
Steve
Steve Prado
Rudy, AR
S/ST4202 H/R 4203
Steves68Nova is offline   Reply With Quote
Old 10-12-2009, 02:57 AM   #6
Bill Baer
Steve
I have heard the same thing and it may be true if you switch from gas to alcohol, I have always run alcohol and the foam in my Jaz fuel cell looks just fine after several years?
Old 10-12-2009, 12:43 PM   #7
dragst racer
If you check around they make foam for alcohol fuels, that is different than the foam that comes in cells that is gas. I boght some once and never put it in just ran with no foam.
dragst racer is offline   Reply With Quote
Old 11-14-2009, 07:09 AM   #8
THE LEGEND
Take out foam.
Another trick for milky oil. Run it Hot. I always get mine to 200 before I park it helps evaporate the water. I ran alky this season in my dragster. I changed oil twice. I probably could've went longer Oil looked fine. Also AMSOIL makes a racing synthetic for Alky engines.
Be careful with the Smelly additive it can gel in your fuel system.
If you sit for more than a week spray carb with wd40 keeps it from sticking.
Alky is corrosive and will wear out your engine parts quicker than normal.
One more thing. The old story about Alky being more consistent is a myth. Especially if your gas carb is set up correctly.
My gas car is just as good as my alky one. Next season I'm switching one of them so I don't need to carry both fuels.
Chip
THE LEGEND is offline   Reply With Quote
Old 04-27-2010, 08:33 AM   #9
Mike Croley
Fuel cell foam is not normally interchangeable , methanol and ethanol dissolves the foam made for gasoline , so check with your fuel cell manufacturer . You do want to keep foam in the cell .
You'll find virtually no difference between major brands of racing methanol and chemical company brands . But beware of very low priced methanol , it's often recycled and not very good for race use .
Mike Croley
dist. for Competition Race Fuels
386-341-4308
Mike Croley is offline   Reply With Quote
Old 04-28-2010, 08:16 PM   #10
283nova
283nova's Avatar
when i worked for the mahoney brothers, we used to use TARR chemical company methanol in the blown alky nostalgia roadster. worked good was really consistent.
283nova is offline   Reply With Quote
