Old 04-22-2019, 08:14 PM   #151
B Parker
Liked 2,314 Times in 455 Posts
Default Re: 69 Camaro B/S
Great looking car. You should be very proud doing a build from the ground up. Barry
Old 04-23-2019, 08:15 AM   #152
Nmbr1GMfan
Liked 1,957 Times in 492 Posts
Looking great.
Todd Greene
Old 04-23-2019, 11:00 AM   #153
Glenn Briglio
Glenn Briglio's Avatar
Liked 822 Times in 264 Posts
Originally Posted by J&S Racing View Post
Under firewall
Thank you.......great job on build
Old 06-16-2019, 05:25 PM   #154
J&S Racing
Liked 288 Times in 78 Posts
Progress has been slow trying to sort out the new dragster motor.
The new shock mounts should be done this week. Hopefully starting getting on it again but every day I see my goal of the Dutch slipping away.
Just got some stuff back from the hydro dipper. Stuff came out great, it’s tough to tell the real carbon from the hydro dip.
Old 06-16-2019, 05:34 PM   #155
J&S Racing
Picked up a 1’x1’ pice of carbon to cover the holes in the dash pad and ended up on a mission to use it all...
Old 08-19-2019, 08:03 PM   #156
J&S Racing
Ok... enough sulking about the new dragster motor, I’ll get into this later but for now it’s time to get back on this stocker.
Honestly, if it was mine I'd face the mounting bosses off about .125 to move the box laterally. The rag joint should accomodate this. The column could be loosened up and lined up accordingly, as well. Then, no header gasket...just a thin bead of sealer like Valco Aluminized silicone.
For what it's worth. -Al
So after some back and forth we decided to give Alan’s idea I shot rather than a “technical tap” on the header. We took about a 1/8 of the bosses and looks like I’ve got plenty clearance even with the header gasket.
Some needed stuff also arrived.
RobbMC starter and battery cables to finish out the wiring
Old 08-20-2019, 08:14 AM   #157
Alan Nyhus
Liked 762 Times in 226 Posts
Glad it worked out. I did it for clearance on #7 and the box. -Al
"That'll never work....."
Old 12-22-2019, 08:42 PM   #158
J&S Racing
Time for a little update....
Once the car was on the ground I felt the seat brackets I made had me sitting a little high. I ended up with these from Rhodes race cars. Much more comfortable and still bolt in stock location.
Plumbing and wiring is just about finished up under the hood.
Old 04-16-2020, 04:37 PM   #159
J&S Racing
Hope everyone is staying safe and healthy!!!
Figured time for a update.
1st off a huge thanks to Glen Sanders. Not only are his rims a thing of art his customer service it top notch!
My original plan was to use the newer style willwood master cylinder. I also wanted to use the bickel brake rod retainer but it turns out they won’t work together.
I decided to just use the Mopar style, I didn’t really want to open and elongate the mounting holes so I found this trick adapter from TRZ Motorsports.
The hole was 5 thou small for the Bickel kit, a little sanding and it fits together perfect.
Old 06-29-2020, 10:08 AM   #160
J&S Racing
Big thanks to Mark Markow race cars in south Windsor CT.
Was able to cross a bunch of big stuff off the list..
Had the rear end centered up and pinion angle set then welded the Calvert perches.
Also had him add a tab for the racepak censor. The pick up had to be machined to fit around the yolk.
Added a net
Getting the car set up for weight has been on my mind for a while. Mark nailed it!! Also provisions above the axle for the small bars and brackets where the rear seat would be for the large bars.
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Copyright © Class Racer.com. All Rights Reserved. Designated trademarks and brands are the property of their respective owners.
