07-08-2019, 12:42 AM | #21 |
Liked 180 Times in 110 Posts
Re: Offset grinding crank ?
The impact is a bit more compression from the added stroke.
Draws .013 more air and then compresses .013 a differential of .026 Plus slightly smaller diameter crank diameter, less parasitic drag. Most engines it is about 1.5 cuin increase. Last edited by Dan Fahey; 07-08-2019 at 12:45 AM. |
07-08-2019, 06:40 AM | #22 |
Liked 9,453 Times in 1,956 Posts
07-08-2019, 06:59 AM | #23 |
Liked 724 Times in 177 Posts
Excuse me!?! Stroke is measured from BDC to TDC so the "differential" is .013", not .026".
07-08-2019, 11:11 AM | #24 |
Liked 677 Times in 290 Posts
07-08-2019, 12:42 PM | #25 |
Liked 248 Times in 107 Posts
No, no more than spec. You just don't have to deck the block as much.
Phil Molski S/C 1623 |
07-08-2019, 05:00 PM | #26 |
Yes. And max compression is dictated by spec limits. Adding stroke does not increase compression except for the additional displacement added to the mix.
07-08-2019, 05:13 PM | #27 | |
Liked 4,453 Times in 1,694 Posts
To me, the indexing and smaller pin size are at least equal in value. BTW, thank you to to Dwight for what you do for racers....Appreciated by 98% of them ,and called names by those who are Left.
We are lucky we don't get as much Government as we pay for..... Will Rogers |
07-09-2019, 08:40 AM | #28 |
Gasket thickness (A) and deck (B) can vary, but total of A+B has to same as or greater than NHRA spec. .000 deck and .040 gasket = -005 deck and .035 gasket or +005 deck and.045 gasket. Give yourself a few extra thousandth to the good side so you can be fearless in tear down.
