05-10-2017, 08:05 AM | #1 |
Liked 56 Times in 24 Posts
Late Challenger Smart Door Glass Controllers
Has anyone experience with wiring the late model Challenger door glass with the smart controllers. The 09-11 Drag Paks have specific controllers that wired different from stock to control the electric windows. Those controllers are no longer available, as I've been told. I tried wiring the OEM controllers the same as the DP, but do not operate.
I have been sifting through schematics trying to piece it all together, but thought I'd ask if anyone has experience in this that may give me a short cut. Thanks
Todd Gross 3323 FS/E,F |
05-10-2017, 11:48 AM | #2 |
Liked 8 Times in 5 Posts
Re: Late Challenger Smart Door Glass Controllers
I have new 08/09 Drag Pak window controllers. PM me John
John Donato Stk / SS 3435 |
06-20-2017, 06:41 PM | #3 |
They are in and they work as intended. Thanks John!
06-21-2017, 09:15 PM | #4 |
Liked 699 Times in 203 Posts
One thing I have found on the DP window controls is they do not like 16v systems.
They will usually work when the car is not running , but when the car is running with a functioning alternator , voltage approaches 18-18.5 volts and the control module shuts down . I fixed the problem on one of the DP's I work on by using a Runtz dropping resister that is made for dropping 12volts down to operate 6 volt gauges on cars that were converted to 12 v.
07-11-2018, 10:45 PM | #5 | |
Scott justo. 2009018 lc22r |
07-13-2018, 08:39 AM | #6 |
Scott, you can try this reducer ,it's made to reduce from 18 volts to 12 for electric golf cart radios. I've had good results with it.
Jeg's part number is 811-conv-00
07-13-2018, 02:29 PM | #7 |
Liked 299 Times in 56 Posts
CAN buss controllers do not like anything more that 18 volts. I have seen systems fail completely at just over 18 volts.
07-14-2018, 05:56 PM | #8 |
Thank you Tom I will try that.car is at the tuners shop right now and the window issue is the last thing to do before its first trip down the track.
07-19-2018, 07:11 PM | #9 |
Liked 604 Times in 177 Posts
I have a 2016 Challenger and need help trying to get the power windows to work. Anyone know how to wire this and make this work? I am not using the factory ECM, but have the factory wiring in the doors. The Drag Pak controllers are no longer available. Thanks, Dyno 763-227-336six
07-20-2018, 03:44 PM | #10 |
Liked 370 Times in 102 Posts
Dyno, just run the AC.
Jerry Heath I/S '93 Cobra FS/J 2010 Mustang "Ebay CJ" |
