Old 02-15-2018, 12:11 PM   #1
jmcarter
jmcarter's Avatar
Liked 2,678 Times in 850 Posts
Default Input needed on Willy’s Restrictor Plate
Need a quick way to knock ~7 tenths off a Super Street car without buying a timer and stop and working to get ratios. Not sure I’ll need those long term anyway so thought the Willy’s housing that has the adjustable plates and mounts under the carb would be a good “cheap and dirty” approach. Any inputs? Thanks
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 02-15-2018, 03:57 PM   #2
Jeff Stout
Liked 654 Times in 254 Posts
Default Re: Input needed on Willy’s Restrictor Plate
I know a bracket racer that has one on a 10.50 car and loves it. The car stayed very consistent and adjustable to always be fast car in class he runs in. Not sure on how much ET he scrubs off with it.
Jeff Stout is online now   Reply With Quote
Old 02-15-2018, 04:18 PM   #3
Lenny5160
Lenny5160's Avatar
Liked 432 Times in 225 Posts
From what I've read, you may or may not be able to kill enough with the Willy's plate. Right on the edge.
EZ Plate will work, but you'll need to carry a variety of plates to dial the car rather than just turning a bolt on the Willy's.
S/ST 51
S/C 53
Old 02-15-2018, 10:38 PM   #4
jmcarter
jmcarter's Avatar
Thanks guys, confirms what I was thinking, hate to kill MPH but if I buy the car I may just unhook the four barrel and see if it will still cut a light and if halfway close use weight to fine tune. This would be a one race deal, guys will be fighting to line up with me first round....get your first round duck right here! If I buy the car will get one of the Sinnett stops and test, test, test.
Thanks again.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 02-22-2018, 07:46 AM   #5
Robbie Welch
Liked 262 Times in 124 Posts
Jim you planning on trying Super Street?
Old 02-22-2018, 08:35 AM   #6
jmcarter
jmcarter's Avatar
It's been known to happen, see my album...linky below
http://classracer.com/classforum/album.php?albumid=577
The Roy Johnson built yellow Duster was the killer car, some success with the full Chassis Avenger most recently before a foray into Stock eliminator. Now working toward a Super Stock legal roller with a Bracket/Super Street motor.
Good luck this weekend!
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Copyright © Class Racer.com. All Rights Reserved. Designated trademarks and brands are the property of their respective owners.
