Old 07-20-2019, 02:47 AM   #11
SGSST109E
Liked 124 Times in 58 Posts
Default Re: rear housing moving ?
When I ran mono springs in the 70's in C/SM we drilled a hole thru the spring. A cobalt bit is the way to go, or you can sharpen a regular one over and over. If I remember I used an alien head bolt with the head on top into the spring perch. Used a threaded piece of tubing as a bit on the bottom. This way it was pinned in the top an bottom
SGSST109E is online now   Reply With Quote
Old 07-20-2019, 07:28 AM   #12
Mike Savelle
Liked 6 Times in 4 Posts
Smile Re: rear housing moving ?
thanks for the replies , a cobalt drill bit is the answer. I knew I could count on Class Racer.
Mike Savelle is offline   Reply With Quote
Old 07-20-2019, 08:44 AM   #13
cad
cad's Avatar
Liked 72 Times in 40 Posts
It wont take much to drill through. We used 1/4 or 5/16 allen head bolts for locating pins.
Old 07-20-2019, 11:00 AM   #14
Jeff Stout
Liked 655 Times in 255 Posts
Drilling safes open I have bits that will work. You can buy them publically. They look like a masonry bit but made for hard plate found in safes.
Old 07-20-2019, 11:56 AM   #15
gsa612
gsa612's Avatar
Liked 280 Times in 139 Posts
To bad you live in Phoenix,if you ever come up to Canada PM me...lol gsa612
Old 07-20-2019, 12:56 PM   #16
Jeff Stout
Tell what size and I can mail it to you. They come 1/4,5/16,3/8,1/2. Don't know the cost to mail in Canada
Old 07-20-2019, 01:30 PM   #17
FED 387
Liked 280 Times in 150 Posts
Carbide or Cobalt drill bits----tungsten bit if you can find one ---theses bits are very brittle so use care when handling or using them---- VERY slow speed lots of oil or coolant,----- drill press only NO HAND DRILLING so as to not work harden the material or ruin the drill bit-- DO NOT RUSH TAKE YOUR TIME doing it--better yet put it in a mill and use a carbide cutter to make the hole --FED 387
Old 07-20-2019, 05:01 PM   #18
Dave Noll
Dave Noll's Avatar
Liked 219 Times in 105 Posts
https://www.mscdirect.com/
https://www.travers.com/
Dave Noll, E/FS ,L/SA 6526
Old 07-21-2019, 01:25 PM   #19
LethalRat
Liked 4 Times in 3 Posts
Or you can buy a set of Calvert split mono leaf springs. They have the locating bolt that goes thru them.
LethalRat is offline   Reply With Quote
Old 07-22-2019, 02:11 PM   #20
Casey Miles
Liked 445 Times in 83 Posts
There is a company called Flex Form, they make composite springs that will save weight, they weigh 8lbs a side and last for ever. Just a suggestion. About $400 for the pair.
Casey Miles
Stock
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Copyright © Class Racer.com. All Rights Reserved. Designated trademarks and brands are the property of their respective owners.
