07-19-2019, 11:33 PM | #11 |
Liked 938 Times in 259 Posts
Re: Trailer Bearings and grease
Mike, do you happen to know the part numbers for the NAPA bearings and seals? Do you just tell the counterman that you have Dexter 5200 lb axles, and that is enough info for them? My trailer tires are not show any unusual tire wear, but it does seem odd that the bearings on the front axle looked fine, but the rears looked so bad. I wonder if the torsion axles are more sensitive to load distribution than leaf spring axles with a center pivot link. My trailer looks level while towing.
07-23-2019, 10:51 AM | #12 |
Liked 1,629 Times in 502 Posts
These are the NAPA numbers that I have been using. I have a small tool box in the trailer that I keep a spare set, grease and a grease gun.
PBR25580 inner bearing PBR25520 inner race PBR6 - outer bearing and race 22532 seal
Mike Pearson 2485 SS |
