Old 01-04-2018, 05:36 PM   #1
SST159
Liked 18 Times in 12 Posts
Default Edelbrock Super Victor CNC 2825
Anyone try or have any input on the Super Victor CNC 2825 SBC manifold and is the CNC work they have done worth anything. This is the CNC version of the 2925. I do know they are port matched to the 1206 gasket but not sure of the rest of the work they claim to have done. Also is it suggested to smooth out some of the rough casting inside the runners or it best to leave it alone. Thanks in advance for any input.
Drew Wonderly
SST 159
SST159 is offline   Reply With Quote
Old 01-05-2018, 09:59 AM   #2
Tom Goldman
Tom Goldman's Avatar
Liked 699 Times in 203 Posts
Default Re: Edelbrock Super Victor CNC 2825
Drew, I cant say about the SBC manifold, but if it's anything like the BBC version, there is very little beyond the port match and some very minor machining at the carb flange .
The gasket/port match was dead on to my AFR heads ,so that was nice ,but I saw no other benefit other than it saved me the work of matching.
I later did some radius work in the plenum and further matching to the throttle stop base along with completely finishing the runners. this netted about 1/2 MPH .
Overall the base manifold was better than previous non Edlebrock manifolds I ran.
Tom Goldman is online now   Reply With Quote
Old 01-05-2018, 10:31 AM   #3
SST159
Hey Tom, Happy New Year to you and Kathy.
I have the piece in hand and from what I see the gasket match is dead on to the 1206 gasket. They went in about 1-1.5" on the blend which was nice however I did that to my current one although I would think the C&C is a little more accurate.The Plenum dividers had just a small amount of work done on each entry but nothing real serious. Plus there is a bit of work done at the carb base. I was expecting a lot more. that all being said and comparing to what you found it seems the real advantage of this piece is the port match and some minor touch up. So we Pay them, do it yourself of have someone do it for you. Once I get my old one off I can do some further comparing. As always thanks for the input.
Drew Wonderly
SST 159
Old 01-05-2018, 01:23 PM   #4
Lenny5160
Lenny5160's Avatar
Liked 432 Times in 225 Posts
I'm not an engine guy but I don't think you want 'smooth' inside the runners. Something about dead air sitting along the walls.
S/ST 51
S/C 53
Old 02-25-2018, 03:12 AM   #5
gnicholson
Liked 4 Times in 3 Posts
Those manifolds respond well to porting especially the plenum . Look at some pics online of what chad speier does to those
gnicholson is offline   Reply With Quote
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Copyright © Class Racer.com. All Rights Reserved. Designated trademarks and brands are the property of their respective owners.
