Old 02-25-2018, 12:05 PM   #1
rod
Liked 17 Times in 13 Posts
Default pan gasket ?
I finally moved into the 21st century, and used a 1 piece oil pan gasket for my gen 1 327. now I need to pull the pan. the ? is, can these be reused or no.
thanks Rod in AZ
rod is offline   Reply With Quote
Old 02-25-2018, 01:01 PM   #2
richie 2
Liked 157 Times in 73 Posts
Default Re: pan gasket ?
the dab of silicone you used on the corners can be tricky to remove...clean 'er up and put it back on.
Old 02-25-2018, 02:06 PM   #3
FireSale
FireSale's Avatar
Liked 236 Times in 127 Posts
Best $40 bucks I ever spent (kinda). Ditto for rubber and steel core valve cover gaskets.
Dale Shearon
68 Mustang 6394
Old 02-26-2018, 12:23 AM   #4
Kevin Panzino
Kevin Panzino's Avatar
Liked 550 Times in 106 Posts
Yep. Cannot begin estimate how many times I have re-used mine.
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Copyright © Class Racer.com. All Rights Reserved. Designated trademarks and brands are the property of their respective owners.
