Old 02-17-2020, 03:27 PM   #1
Mike Graham
Liked 299 Times in 56 Posts
Default Garage sale
351c stock eliminator engine minus carb. older technology,but good stuff. Never started after freshen. Make good backup or bracket engine SOLD
JPT c-4 transmission. full torrington reverse valve body. 2.43 low (stock) $1200
8 inch A-1 converter for c-4 Flashes about 5500 behind 351c $600
9 inch rear end for mustang drum to drum. 5.14 spool nodular 61.25 drum to drum
case daytona support. aftermarket 31 spline axles $600 sale pending
MSD 6al 6420 new in the box $125 SOLD
MSD 6a 6201 new in the box (box has some staining) $125 sale pending
MSD 2 step 8732 for 6425 new in the box $60
Summit sum850602 cdi new in the box (box has staining $60
BBC Edelbrock performer 2-0 intake. bolted on never used $135
BBF Edelbrock Victor 460 intake. used holley or thermoquad $215
Childs and Alberts rods 460 ford with bbc journal .990 pins used $125
Comp cams superstock roller cams various grinds $125
Mike Graham 602 540 4262 leave message
M_Graham@testcrafters.com
Mike Graham is offline   Reply With Quote
Old 02-17-2020, 09:29 PM   #2
Kirk Morgan
Liked 52 Times in 30 Posts
Default Re: Garage sale
What is the first gear ratio.
Thanks
Kirk Morgan is offline   Reply With Quote
Old 02-17-2020, 09:48 PM   #3
Mike Graham
2.43 low. stock ratio
Old 02-17-2020, 10:02 PM   #4
Jeff Stout
Liked 655 Times in 255 Posts
Mike I will buy the msd6420 from you. I will call to come to you. I cant be at Nats. Thanks jeff
Old 02-17-2020, 11:09 PM   #5
Murphy
Could you tell me the measurements drum to drum and were you are at
Murphy is offline   Reply With Quote
Old 02-18-2020, 01:32 PM   #6
Muscrate
I wrote you in private for the c4
Muscrate is offline   Reply With Quote
Old 02-18-2020, 03:17 PM   #7
Dave Turner
Dave Turner's Avatar
Liked 334 Times in 132 Posts
PM sent Mike.
Dave Turner #1153
Old 02-19-2020, 08:40 PM   #8
Murphy
Do you still have rear end if so please call for one to 779 three 479
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Copyright © Class Racer.com. All Rights Reserved. Designated trademarks and brands are the property of their respective owners.
