Old 11-11-2017, 04:33 PM   #1
drgrcr1156
Liked 2 Times in 1 Post
Default Spragless Torque Converter
Is it possible to break a spragless torque converter?
drgrcr1156 is offline   Reply With Quote
Old 11-11-2017, 09:44 PM   #2
hookdaddy
Liked 8 Times in 3 Posts
Default Re: Spragless Torque Converter
Absolutely! been there, done that
Don Scholl
d.scholl@comcast.net
145Y Stock - 145H Super Comp
hookdaddy is offline   Reply With Quote
Old 11-12-2017, 10:24 PM   #3
Marc
Marc's Avatar
Same here.
Marc is offline   Reply With Quote
Old 11-13-2017, 10:18 AM   #4
Tom Goldman
Tom Goldman's Avatar
Liked 696 Times in 201 Posts
Fins can still break off and cause major damage and the lugs that hold the spragless hub to the stator can shear off .
You also could have a broken or spun stator tube in the pump that will also act like a broken converter .
Old 11-13-2017, 07:15 PM   #5
drgrcr1156
I was sure that was the case when my converter broke before the end of the season. What was all the hype about spragless vs sprag? I replaced it with a backup 8"sprag type which was not made for my current combination and it outperformed the 9" spragless I had been using for 5 years.
Bob
Old 11-14-2017, 11:37 AM   #6
Lenny5160
Lenny5160's Avatar
Liked 432 Times in 225 Posts
With converter problems commonly coming back to the sprag, that is one problem that you won't have with a spragless!
I'm not surprised at all that an 8" sprag converter outperformed the 9" spragless. It most likely had a higher stall, which I've always seen to be quicker and more consistent as long as you can handle the increased RPM at the finish line.
Also, spragless converters tend to build a little more heat and be down just a little MPH compared to an identical converter equipped with a sprag.
With that said, I am still a fan of spragless converters.
S/ST 51
S/C 53
Old 01-12-2018, 08:48 PM   #7
B1Ken
When I see guys "ripping" the throttle at the finish line I shudder to think what that must be doing to the sprag. I prefer spragless, " just because", but I could be wrong.
B1Ken is offline   Reply With Quote
Old 02-26-2018, 11:09 PM   #8
Shake & Bake
Liked 31 Times in 27 Posts
Talking Re: Spragless Torque Converter
I too prefer a spragless converter.
Shake & Bake is offline   Reply With Quote
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Copyright © Class Racer.com. All Rights Reserved. Designated trademarks and brands are the property of their respective owners.
