Old 07-09-2019, 03:43 PM   #1
ausby
ausby's Avatar
Liked 31 Times in 16 Posts
Default radial tire in super gas?
anyone have any luck running radial tires? ive been running stiff sidewall slicks and I keep beating my sidewalls out after about 100 passes. wonder if a radial will hook until I go on the stop.
ausby is offline   Reply With Quote
Old 07-10-2019, 02:34 PM   #2
Gary Federico
Default Re: radial tire in super gas?
A radial track prep is key, which u won't see at any Nats. or Pts. race. As well as they are very unforgiving, if you turn the tire its over. Bad combo for S/G in my opinion.
Gary Federico 1814 SST
Gary Federico is offline   Reply With Quote
Old 07-10-2019, 02:38 PM   #3
Lenny5160
Lenny5160's Avatar
Liked 432 Times in 225 Posts
My 9" radials are great in Super Street. I know that isn't the same as a Super Gas car, but...
S/ST 51
S/C 53
Old 07-10-2019, 03:10 PM   #4
ausby
ausby's Avatar
that's kind of what I was thinking. track prep would be key. just trying to launch so hard to hit the tree. I need a 2200lbs roadster I guess.
Old 07-10-2019, 04:09 PM   #5
Ken MacNicol
Ken MacNicol's Avatar
Liked 23 Times in 10 Posts
Remember what we talked about this weekend and take it to some one.
Ken MacNicol is offline   Reply With Quote
Old 07-11-2019, 12:19 PM   #6
ausby
ausby's Avatar
my car normally works great. it just all of a sudden does this. I put tires on and im good for another 100 passes. I took some slow motion video of robs car and I think rocks are falling out of his car causing his issue. how many passes do people usually get out of a set of slicks doing this type of racing versus bracket racing? im sure leaving at 5000 is harder on tires than 3500
Old 07-11-2019, 01:26 PM   #7
Tom Goldman
Tom Goldman's Avatar
Liked 699 Times in 203 Posts
High HP cars ,1000+ , will usually start loosing reaction time and 60' consistency between 60 -70 runs . Depending on how hard the car launches .
I give my tires to a Super Street racer who gets another 50 to 60 ,or until I give him the next set.
Like Gary said ,track prep at Div/Nat races is good for a soft leaving radial car ,but I wouldn't trust it to be there for 6-7 rounds of Super Gas .
Old 07-12-2019, 08:56 PM   #8
thomas r polk
try using tubes
thomas r polk is offline   Reply With Quote
Old 07-15-2019, 10:49 AM   #9
ausby
ausby's Avatar
thanks for the input. I may try some tubes. im already running a stiff sidewall tire. maybe tubes will give it more support
Old 07-17-2019, 09:59 PM   #10
Charlie Yannetti
Liked 179 Times in 77 Posts
I investigated trying a radial tire on my SG car, cause I'm silly that way sometimes.. OK.. OK.. not just sometimes.. the engineer at MT told me that their radial tire probably would work on my combination, but that they life of the tire would be deminished because of going on and off the stop.. I LISTENED..
Speaking of tires, I will have two sets of MT 33x15-15S, part number 3080, at the Atco points race.. one set with 35 runs, the other with 26 runs.. $350 per set...
Charlie Yannetti is offline   Reply With Quote
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Copyright © Class Racer.com. All Rights Reserved. Designated trademarks and brands are the property of their respective owners.
