Old 06-26-2019, 06:33 PM   #11
sean1970ss
Liked 9 Times in 5 Posts
Default Re: High rpm 427 bbc build 940hp?
When I ran a short stroke I shifted 9400-9600 but never knew how much power 440" motor made. Did not have the $$ to dyno. Biggest problem was the valve train. Was fortunate to have a few really sharp guys help me out.
sean1970ss is offline   Reply With Quote
Old 06-26-2019, 08:15 PM   #12
RonP
Liked 24 Times in 11 Posts
We had a customer that purchased the 402ci D/SM (at the time) from JEG in the mid 1990's. That engine dyno'd at +900hp. I was working at Kromerkraft at the time and we built a set of headers for that engine and gained 5hp. I remember somewhere around 940 or 950 back then.
Thanks, Ron
RonP is offline   Reply With Quote
Old 07-09-2019, 11:17 AM   #13
joespanova
Liked 13 Times in 11 Posts
Originally Posted by sean1970ss View Post
I was talking with a guy he said they dynoed a 427 bbc here while back made 940hp at 9200rpm. .100 over, 14.1 compression .903 lifter, 55mm cam light pistons, and rods tunnel ram. AFR 315 heads 2.300 valve.
Is that possible??? Never seen one make that much power.
I'd like to look at those heads , because its highly unlikely , no , make that definitely NOT anything close to what AFR produced...so this suggestion is somewhat "misleading". The only thing AFR 315 about those heads is the casting. Contemporary t-ram / carbs , vac pump and all the other bells and whistles .....
Old 07-10-2019, 03:22 PM   #14
sean1970ss
Tony Mamo did the heads. Never witnessed it or had anything to do with it.
Old 07-11-2019, 01:14 PM   #15
joespanova
One phone call followed up with another , confirmed all I need to know about that j@ck@***.
Old 07-17-2019, 07:32 PM   #16
sean1970ss
Not quite sure what your problem is with me or Mamo but it was just a simple discussion. Weather it happened or did not does not matter. Some say yes it is doable but not meant to be a debate.
Old 07-25-2019, 08:47 AM   #17
joespanova
Now , you tell me , where exactly your "take away" from anything I said suggests I had a problem with you......
Mamo , on the other hand , is still a Jack@@s
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Copyright © Class Racer.com. All Rights Reserved. Designated trademarks and brands are the property of their respective owners.
