02-15-2018, 11:24 PM | #1 |
Liked 250 Times in 101 Posts
Question on Caltracs
I am about to order my Caltrac split springs springs for my 67 Cuda that will be running in K/SA. On Calvert they give me an option from a 1+ height, neutral -1 and -02 heights.
Which one would be the best choice? |
02-16-2018, 02:56 AM | #2 |
Liked 236 Times in 127 Posts
Re: Question on Caltracs
That body style is similar to my 68 Mustang coupe. I had the lowered springs and had tire clearance issues. Replaced them with the lifted versions - +2. I think - and I run 28/10s in there with mini tubs. Might be able to fit 30/10.
02-16-2018, 04:21 AM | #3 |
thanks, i have a set of the older SS springs on it now. and a old set of MT 29" slicks. I will see how it looks and fits and make my determination then.
02-16-2018, 05:34 AM | #4 |
Liked 1,808 Times in 572 Posts
Our A body stockers are at neutral.
John used to make a narrower spring that made tire clearance easier to work with on A Bodies. Duster and Demon really do not need them but they make it much easier on earlier A body cars and some of other A body stuff like 67 to 72 Darts.
02-16-2018, 05:43 AM | #5 | |
Thanks John, one day owe you a big dinner |
02-17-2018, 08:17 AM | #6 |
Liked 9,453 Times in 1,956 Posts
After you get the springs and you want to adjust ride height, it is easier to adjust up than down.
02-17-2018, 10:05 AM | #7 |
Liked 226 Times in 118 Posts
With respect to the commenters (and lots of other racers who run his stuff), I would call Calvert.
02-19-2018, 11:14 AM | #8 |
Also keep in mind whatever you get, when you first install, they will settle and change. At least mine did. I got stock height and was worried it was too high at first but they settled in nicely.
