Old 02-23-2021, 10:43 AM   #1
Eric Merryfield
Eric Merryfield's Avatar
Liked 471 Times in 114 Posts
Question Tire pump for the RV tires
Anybody have a good tire pump lead to get those tires up to 120Lbs? Alternatively a good method that doesn't DEFLATE your tire using the on board RV air compressor?
Thanks
Eric
Eric Merryfield 1883 STK
Old 02-23-2021, 06:27 PM   #2
1matcoman
1matcoman's Avatar
Liked 277 Times in 110 Posts
Default Re: Tire pump for the RV tires
Eric, most of the guys that I RV with carry a “pancake” style electric compressor like this:
https://www.tractorsupply.com/tsc/pr...CABEgI_lfD_BwE
Or, this one is super handy if you don't mind the expense:
https://www.amazon.com/VIAIR-400P-Au...ag=googhydr-20
I, personally, air mine up to 110 to 115psi with the onboard air system because it goes through an air dryer and imo is better than a compressor. Yes, it’s slow! You have to pump the brakes on the mh until the compressor kicks in but it works.
Old 02-23-2021, 07:23 PM   #3
jmcarter
jmcarter's Avatar
Liked 2,678 Times in 850 Posts
I use the pancake style also, depending on your valve stem/wheels in dual rear wheels a gauge similar to this is great for hard to reach spots.
https://www.amazon.com/gp/product/B0...ref_=pd_gw_unk
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 02-24-2021, 01:02 PM   #4
Eric Merryfield
Thanks, ordered the Tractor supply model, picking it up later today.
Old 02-24-2021, 06:53 PM   #5
FED 387
Liked 280 Times in 150 Posts
The pancake compressor is not going to do the job!!! First the recovery rate is going to take too long (2.3CFM)and the upper limit of them is only about 150 PSI-- it will take you forever to do anything .---Are you talking 22.5 TRUCK tires like on a Diesel Pusher MH or tires on a Class A or Class C that take 90-100 PSI ????----you are going to need a Compressor !!!!! not a flyweight pancake unit-- Save your money on this--FED 387
Old 02-24-2021, 08:29 PM   #6
1matcoman
1matcoman's Avatar
FED,
While I will admit that this is not the ideal way to add air to a 22.5 motorhome and/or truck tire, it will most definitely do the job. I have seen it dozens if not hundreds of times. I don't see to many motorhomes with enough room to carry a large compressor, so these little portable units work just fine.
Old 02-28-2021, 06:02 PM   #7
novassdude
Liked 133 Times in 49 Posts
One thing to look into when shopping for the pancake compressors is to make sure they have a relief that releases the air when the compressor shuts off. It makes a big difference if you are running it off of a generator. I have Craftsmen that has it and can easily run it off a 3500 what generator. I friend bought the harbor freight version. And his would about kill a 4500 watt generator if he tried to start it with pressure in the tank.
novassdude is offline   Reply With Quote
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Copyright © Class Racer.com. All Rights Reserved. Designated trademarks and brands are the property of their respective owners.
