Go Back   CLASS RACER FORUM > Stock/Super Stock Associations > IHRA Pure Stock Challenge
Old 08-26-2021, 01:24 PM   #1
Dan Fahey
Dan Fahey's Avatar
Liked 180 Times in 110 Posts
Default K/SA finally
Finally converted to K/SA
Took 4 weeks to put in the new cam
Mostly weekends.
Started by replacing the Stickers and new Car Number 1057.
Cleaned and polished the Valve Covers.
Painted the Intake, pulled the oil pan cleaned and paint.
New gadgets, Opti and Water Pump.
Keeping the TriY Headers hooked up to the Mufflers for now.
Still Licensed to drive on the street.
Drove the car to the Car Wash and got it freshened.
Had to use the F/PS BIN files to get it to shift.
Cruises fine in OD and Converter Locking
Will have to change Tables to Open Loop and other tuning.
Next investment are a set of Stahl Headers.
My of may not drop the Mufflers.
May have an open outlet made for racing.
D
Old 08-26-2021, 03:07 PM   #2
jmcarter
jmcarter's Avatar
Liked 2,705 Times in 853 Posts
Default Re: K/SA finally
The gear you’re probably going to end up with may end your “cruising” days. Congrats on making the leap.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 08-30-2021, 03:54 PM   #3
Dan Fahey
Dan Fahey's Avatar
Thanks...does ok taking it to the car wash. ;-)
Still have the Mufflers on it.
Was planning on going to Maple Grove Points Meet.
It rained and weather looked iffy and had done no testing.
Thinking my TC SW is corrupted.
Had to use the original Pure Stock tune.
Played with it over the weekend.
Got some help from TunerCat.
Did make some successful changes to run better.
Have another older laptop and War Machine with working copies.
Made changed using the WM. Will see if that works.
Loading does not seem to be an problem.
D
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Copyright © Class Racer.com. All Rights Reserved. Designated trademarks and brands are the property of their respective owners.
