03-16-2018, 03:26 PM | #1 |
Liked 33 Times in 11 Posts
Cleaning out the garage
402 BBC Diamond pistons new/unused 4.191 bore .0415/.043/3mm coated top. Will throw in ring set with 4 dyno pulls. $700
JE 396/350 pistons (6), Crower rods 2.200/.927x2.500 (2 new), new pins. Need 2 pistons to complete $500 290 Heads Up heads, one repaired but would replace, with valves $800 TH400 reverse valve body, alum drums, deep pan, locking dipstick, less than 100 runs since new, 30 since rebuild $900 Jesel belt drive BBC 9.8, everything there but would replace belt and seals $500 Jesel belt drive BBC 9.8, excellent with brand new belt $650 BBC 904 Isky lifters excellent condition $500 BBC 904 Isky lifters fresh from rebuild $700 Misc roller cams std bore $150 Alum CSI 168t auto flexplate $60 12 bolt street gears 3.90 $75 Q-jet prepped carbs $300 each 292 head castings, 2 sets $250 ea set 049 head castings $300 291 heads, Ferrera valves, dual springs, need rebuilt $600 215 heads complete takeoff $350 236, 049 and 820 single castings $100 ea 6223 crank std/std nitrided, ex cond $350 454 7416 steel crank need turned $150 454 cast cranks need turned $50 ea 327 sj 1965 block cleaned, needs honed $150 454 block .030 with one sleeve, may clean up $300 454 block std $500 396 block std bore $250 402 block from Hettler engine 4.193 currently, filled, 2 bolt, clean up at 4.200 $150 82-92 camaro plastic headlights, lightweight, new in box $60 Merlin intake, oval port, ported for super stock $400 Quay headers for 82-92 camaro 2 1/8- 2 ¼ step, dyno time only $500 New Dana 60 5.57 Richmond pro gear $350 85 camaro ground effects $100 82 camaro factory fiberglass hood, one corner needs minor repair $300 14x32 M/T radial slicks, 35 runs $200 All plus shipping call or text 9 19 9618505 Last edited by bert powell; 04-10-2018 at 11:11 PM. Reason: Remove sold items |
03-16-2018, 06:21 PM | #2 |
Liked 168 Times in 49 Posts
Re: Cleaning out the garage
03-16-2018, 08:16 PM | #3 |
Liked 141 Times in 63 Posts
Pm sent
Chris Chapman 1969 Chevelle NHRA F-G/SA 1090 |
03-19-2018, 01:40 PM | #4 | |
email sent
03-19-2018, 01:48 PM | #5 |
03-28-2018, 08:30 AM | #6 |
Chipper Chapman PM sent.
03-29-2018, 07:22 PM | #7 |
Sent you a message
