12-06-2020, 12:53 AM | #41 |
Liked 223 Times in 88 Posts
Re: Super Stock GT... new rules
I see they kept the cage requirements down to GT/GA even after they changed the weight breaks but state that if you run 9.99 or under a cage must be installed. I figured they had moved it down to GT/KA and never bothered checking.
12-08-2020, 12:13 PM | #42 |
Liked 453 Times in 155 Posts
If my memory serves me correctly ( it usually doesn't ) there were three class's in Super Modified. A was for big blocks with an 850 carb and B & C were small block cars with a 750 carb. I don't remember the weight breaks anymore, but IHRA ran that as a eliminator. I also think you had to use Factory heads and were only allowed porting 1" in on the intake surface an 1" in from the bowl side. For those of you that were involved in Super Modifieds at the time, please refresh my memory.
12-08-2020, 12:31 PM | #43 |
Liked 51 Times in 16 Posts
75' First year on one A/SM . 10.5 lbs/ci
76' A,B,C. A became C at 10.5, B was 9.5 and A was 8.5.lb/ci Changed again when modified eliminator was shut down in 1981 Today, there is A thru I/SM in Comp and is entirely different. However, modified stock is similar to the old SM rules ex.SS/AS is 8.5 with 1 carb. Last edited by blkjack; 12-08-2020 at 12:39 PM. |
12-10-2020, 12:44 PM | #44 |
Liked 167 Times in 81 Posts
And C was inline head only, basically a class for Chevy's.
Tim Schmackpfeffer 762 SS |
12-10-2020, 02:00 PM | #45 |
Liked 822 Times in 264 Posts
Not just for Chevies anymore
12-10-2020, 02:48 PM | #46 | |
Liked 693 Times in 208 Posts
12-10-2020, 02:54 PM | #47 | |
Liked 1,453 Times in 541 Posts
The old class resembles more the current SS/Modified Stock classes than Comp Eliminator Super Modified. |
12-10-2020, 03:42 PM | #48 | |
Liked 660 Times in 283 Posts
Click the link in post #24 |
12-15-2020, 10:50 PM | #49 | |
Liked 676 Times in 260 Posts
That was my gripe with some rules and builds that have been showing up that skirt the rules. If they weren't out there why the need to be rewriting (change the language) of the rules?.
Adger Smith (Former SS) Last edited by Adger Smith; 12-15-2020 at 10:51 PM. Reason: sp |
