01-24-2021, 08:24 PM | #1 |
Liked 16 Times in 14 Posts
Valve spring pressure
On a dual valve spring with the inner spring slightly shorter, when checking spring pressure with rimac tester, do you need to account for the inner lip from retainer. When spring is on head and closed, the inner spring is not at same level as outer. Valve spring tester is flat and contact with inner spring is about .060 lower. I know I'm rambling, but maybe someone understands my question. Thanks.
01-24-2021, 08:46 PM | #2 |
Liked 224 Times in 89 Posts
Re: Valve spring pressure
I use a .100" washer, a lot of retainers have a step about .100".
01-24-2021, 08:51 PM | #3 |
Paul, I have used a washer and seen dad do same for years. I didn't know until recently how much difference it makes if you leave it out.
01-24-2021, 09:00 PM | #4 |
Liked 26 Times in 15 Posts
Like the others said, you need to check it the same way that it will be installed. Same retainer and some type of shim to simulate the step in the head. What you really need to pay attention to in that setup is coil bind on the inner spring.
Bill Koustenis |
01-25-2021, 07:09 AM | #6 |
Liked 124 Times in 58 Posts
I always check mine using the retainer
01-25-2021, 07:30 PM | #7 |
Liked 510 Times in 200 Posts
I use the retainer right on the spring and just add the retainers thickness to the installed height on my Rimac tester. If there is a step at the bottom, add an appropriate washer that fits.
That’s the way it runs on the head and as was mentioned is a better way to see the actual pressure and check distance to coil bind
Rich Biebel S/C 1479 |
01-25-2021, 10:31 PM | #8 |
Thanks guys. Always used the washer method, but nice to know about the retainer method when I lose the washer. lol.
01-25-2021, 10:34 PM | #9 |
Liked 676 Times in 260 Posts
I machine a shim or find a shim the same thickness as the retainer step/steps.
That way you are checking actual pressure and coil bind/coil bind clearance.
Adger Smith (Former SS) |
01-26-2021, 08:00 PM | #10 | |
Liked 186 Times in 63 Posts
