10-14-2018, 08:16 PM | #1 |
Liked 8 Times in 4 Posts
Paint stripper
63 Plymouth with aluminum front end. Is there a paint stripper out there to use on this lightweight aluminum. Strippers usually generate a lot of heat, which I want to avoid. Hope someone has some insight into this.
10-14-2018, 09:50 PM | #2 |
Liked 41 Times in 24 Posts
Re: Paint stripper
I would assume some sort of aircraft paint stripper would work since most are aluminum
Bruce Cameron 68 Nova 396 E/S 68 Camaro SS/? ex Checkmate Modified |
10-14-2018, 11:29 PM | #3 |
Liked 20 Times in 15 Posts
Re: Paint stripper
Paint strippers don't generate heat. Methylene chloride works through the molecules of the paint and breaks the bond. That's why the paint lifts. Some paint strippers have acid or alkaline to help break the paint bond. Usually this type is used for catalyzed paints. The acid or alkaline will attack the aluminum. Look for a paint stripper that washes off with solvent and not water. Scuffing the paint with 80 grit helps the stripper work faster. Cover the stripper with cheap plastic to keep the stripper from drying out. If doing it inside, don't use a kerosene heater. It produces phosgene gas, mustard gas...WW1.
10-15-2018, 12:12 AM | #4 |
Liked 57 Times in 23 Posts
Re: Paint stripper
call air craft spruce, 1 877 477 7823. they have remover for alum skin. planes use alum skins. other number is 1 800 861 3192 , customer service.
10-15-2018, 11:09 PM | #5 |
Liked 104 Times in 59 Posts
Re: Paint stripper
Eastwood has some new kind of stripper, don't know anything about it just saw the ad.
10-16-2018, 12:14 PM | #6 |
Liked 236 Times in 127 Posts
Re: Paint stripper
D-Zolve 15-33 R showed up in a search on this topic. It's approved by Boeing and the Air Force. Non toxic brush or spray on.
From SolventKleene Inc http://solventkleene.com/
10-16-2018, 03:23 PM | #7 |
Liked 223 Times in 118 Posts
Re: Paint stripper
These guys have answered several questions for me.
https://www.autobody101.com/forums/ |
