12-11-2017, 07:42 PM | #1 |
Liked 231 Times in 97 Posts
1974 Chevy Nova Excellent S/ST or Bracket Car
S/ST, S/G or brackets
Car has raced in Division 4 area since 1975. Ladder bar back half car. Glass Hood, front/rear bumpers/ deck lid, all lexan windows. Car weighs 2520# wet race ready minus driver. 12 Bolt with spool 35 spline mark Williams axles 4.88 gear. Weld lites. 12 point cage with window net, car will certify 8.50 with no problem and will have certified if the buyer needs it. Still has stock fire wall with front floor pans (no rust) has 2 tone presentable but older paint. BG280 pump, removable steering wheel, sbc motor & mid plates, comes with all autometer gauges and 6 AL ignition. Wilwood front disc brakes, Linelock, all brake lines are braided lines front to back. Car can fit 14x32's, car currently has M/T 29x10.5's, QA1 coil overs front and rear. Kirkey seat, sheet metal dash,car is setup up for the vertically challenged under 6'. Belts will need to be recertified to certify to 8.50 Rack & Pinion steering with fatman upper & lower A arms Have all receipts on all parts purchased, books, etc.. Car does have data plate and Clear Tx. Title Car runs 9.70's with sbc Have photos, serious only, car is being sold as roller but 358 alum. head sbc and glide with shifter and converter are available. $8500 roller $10,500 with Glide (brake, HD pump th400 input shaft, straight cut gears,1.96 1st gear), 9 inch 5500 stall converter and hurst shifter 832-727-0326 Link to my facebook page for photos https://www.facebook.com/nick.hoffman.9406 Last edited by nickh; 12-11-2017 at 09:57 PM. |
