Old 10-22-2017, 02:42 PM   #1
Gary Leasure
Default Complete Patterson 306 SBC Comp / Super Stock Engine
Complete 306 SBC Patterson Comp Engine Carb to Pan – $6000.00
Would make someone a really good Super Stock Engine
18 degree Bowtie cylinder heads Rolled to 15 degree heads ported by Ron’s, Hogan sheet metal intake, Jesel shaft rocker assembly, push rods, Short Block –Bowtie 184 race block, 4.020 bore, 50mm roller cam bearings, 3.020 stroke crankshaft, 50mm roller cam and lifters, Jesel belt drive timing set up
-Front mount MSD distributor, plug wires, crank trigger, and all mounting hardware
-ATI aluminum shell damper, Stef aluminum oil pan with right side kick out and heater, external belt drive oil pump, remote oil filter with all of the lines, left hand high torque starter and mounting hardware. This motor has been disassembled and all parts can be inspected.
7 in. A-1 torque converter built for this engine, 5 passes on it
contract - Gary Phone (330)727-6646
Gary Leasure is offline   Reply With Quote
Old 12-30-2017, 01:11 PM   #2
Gary Leasure
Default Re: Complete Patterson 306 SBC Comp / Super Stock Engine
Sold
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Copyright © Class Racer.com. All Rights Reserved. Designated trademarks and brands are the property of their respective owners.
