#71 |
Liked 53 Times in 38 Posts
On the HP increase, and not sure how the ford rockers look, but on a small block Mopar, Comp claimed 20-30 HP increase using their roller tip steel shaft rockers over the stock stamped ones.?
Mike |
#72 |
Liked 184 Times in 113 Posts
Have an LT1 with SA Stock Rockers on 7/16 stud.
They do not need push rod guides. Is there any performance advantage going to a Roller Tip or full Roller Rocker? I have a set of 1.6 GM SA Roller Rockers. Can the Cam be ground and use the 1.6 GM RR’s if it meets Lift Requirements? |
#73 | |
Liked 1,443 Times in 302 Posts
Unless your combo came with 1.6 they are not legal. Whenever someone asks for a performance gain report on one part, the answer would be no. The entire combo needs to be considered. Especially cam and springs lifters pushrods etc. when you are talking legal stocker parts, it all has to work together.
James Schaechter 3163 STK |
#74 |
Liked 27 Times in 14 Posts
PRW's are pretty good. We sold a few sets of the stainless units and had them NHRA approved. I actually have a 1.5 ratio set for some dumb reason. Must have been spare shelf parts......... like the Sherman lifters..........
Our shelf did ban them to a specific corner............ |
