Old 09-16-2013, 08:52 AM   #1
John Nechiporchik
Liked 13 Times in 7 Posts
Default Intermittent no start condition
I have an intermittent no start condition on my 98 Pontiac Stocker, 350 with Accell Calmap ECU. Randomly, the car will crank but not start. It might start 10 times in a row then the 11th. time ....crank, no start. Let it sit for a few minutes(5-10)...and it fires right up.
Recently, had a battery go bad....replaced it. The only other change was to the fuel. At Martin, had to switch to Sunoco as VP was not available.
Because it is intermittent, I have not been able to determine if this condition is fuel or ignition related. It has an MSD Digital 7.
Happened yesterday in the staging lanes at a test /tune.....waited about 5 minutes and it fired right up.
Anyone experience anything like this?
Thanks.
John Nechiporchik is offline   Reply With Quote
Old 09-16-2013, 12:33 PM   #2
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
Default Re: Intermittent no start condition
Dave Noll, EF/S ,?/SA 6526
Old 09-16-2013, 01:52 PM   #3
countrypuppy4865
countrypuppy4865's Avatar
Liked 229 Times in 71 Posts
Get a spark tester to verify that you have fire. If no fire, suspect optispark or ignition module on coil. If fire is present and it won't start, try pouring a little gas into the intake through the throttle body opening. If it starts when pouring gas (not the same gas that you recently changed to), it will be a fuel problem. It could possibly be bad injectors, or it could be fuel contamination. Just a few ideas.
Jimmy "Cooter" Hidalgo, Jr.
4865 E/SA '04 GTO
4865 SS/GA '99 Firebird
Old 09-16-2013, 02:49 PM   #4
John Nechiporchik
Thanks for the ideas. What fails on the optispark? I've seen references to this before as a problem area.
Thanks
Old 09-16-2013, 04:14 PM   #5
Steve Williams
Thanks
The optical sensor gets knocked out usually by a foreign substance. Oil, water. A quick continuity check of the harness should be done. Manipulate the wires as you do this. They can and do go bad as well.
Steve Williams is offline   Reply With Quote
Old 09-16-2013, 05:45 PM   #6
John Nechiporchik
This thing has an MSD Distributor Cap,coil (HVC2) and crank trigger.
Old 09-17-2013, 10:23 AM   #7
buzzinhalfdozen
Liked 11 Times in 8 Posts
Yeah quick search looks like it does have the LED, hopefully it's in a position that you can see it. Without the crank input I'd imagine you will have neither spark or fuel activity. As SS3011 stated your set up MAY require a cam sync input to operate again not knowing your system it is merely a guess,any way of finding out how it's set up? Do you know who installed and set up the system, that would answer alot of questions. Again IMO I'd start by verifying the LED is blinking first.Good luck. Joe
Joe Buchanan SS/BX 3117
Old 09-17-2013, 11:01 AM   #8
Rich Biebel
Rich Biebel's Avatar
Liked 557 Times in 217 Posts
I ran my LT-1 with an Accel gen VII and a crank trigger.
I used an MSD 7al2 until it failed and than an MSD Digital 6
I did not send the crank trigger into the Accel ECU..
I ran it just like any std non efi engine. Timing was locked and set at the trigger.
I felt since I was new at this ....it was simpler and it was...
I gutted a stock distributer and added an MSD cap and rotor...
So my fuel pump and ignition were basically outside of the ECU...
The injectors of course have to run for the engine to start...
The tests Rob said to do should reveal the problem.....but you have to get it to NOT start first....
A cam sync sensor as I recall was only needed if your were running your EFI as a sequential firing order.....
P.S. I could not get my car to even start the first time I tried......wiring issue. ECU to MSD....
Rich Biebel
S/C 1479
Stock 147R
Old 09-17-2013, 11:14 AM   #9
John Nechiporchik
Spoke with the previous owner/builder.
The Accell Calmap only controls the fuel map. The other functions(timing, rev limiters etc) are managed thru the MSD box. Rich, this appears to be similiar to your set-up.
I wiil get a spark tester and noid light tonight and perform the tests that Rob indicated.
Is there a universal noid light or do I need to buy the kit that has injector brand specific lights? I believe my injectors are Bosch.
Old 09-17-2013, 11:24 AM   #10
buzzinhalfdozen
Ok, so basically the MSD is sending a tach signal to your EFI which it needs to indicate that in fact the engine is running. So you're still back to the basics, which can be indicated by a blinking LED, no blink, no start. I prefer the noid lights with a short pigtail on them so I can position it for easy viewing while cranking, if you have a helper this is a non issue. Look at your injector connector and get a light with similar terminals, as they've made a few different types over the years, there are some "universal" ones to chose from.Joe
