Old 07-03-2011, 06:08 PM   #71
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
Default Re: Some "Dime Rockets" for the 4TH!
Cherokees are not in the Class Guide. Grand Cherokees are starting in 1996. The 1999 Grand Cherokee and the 2001 and up Dakotas with the 287 (4.7 V8) are also a good choice, just don't believe that motor can be raced for cheap.
stock up on head gaskets and do something with the valve seats (they like to fall out)
btw, there's some special tools that you'll need....
Old 07-03-2011, 07:12 PM   #72
Robert Swartz
Robert Swartz's Avatar
'78 Firebird Formula has a 19.18 break, so it is a natural T car and will fit U with weight.
Late 70's 305 2bbl SBC? I had really overlooked this as a viable combination.
My 79 Firebird body is setting in the corner of the garage with the nose off. If there is no real difference in the tail lights, I need to replace the fenders and hood anyway. Finding a complete front clip for a 78 Formula might be a tall order?
I'd need to know the correct the correct carbuerator. What about head numbers, correct intake(s). Would this combo be a flat top or dish piston motor. With the 2bbl and small cam, this thing would be real limited on rpm, what 6000-6200 max? Scarey thought but, you could almost get away with stock press fit pistons with this.
Neat thing is, all I'd need to do is tie the sub frames, do the front end, take the 10 bolt to Moser. I wouldn't even need to put the roll bar in for this low a class! Better yet, I could run the Indy Points meet, less than an hour from my house!
You guys serious, I'd offer the car for a corroboration effort. I already have the Hooker super comp headers, Moroso springs, sub frame connectors, Cal-tracs and mono leaf springs, a torque converter and wheels. Just tossing something out there. It could be the first Class Racer special?
Robert Swartz - Swartz & Lane 66 Chevy II Pro
95 Achieva EF/SA, 78 Mustang II U/SA (work in progress) #354 stock
Robert Swartz is offline   Reply With Quote
Old 07-03-2011, 07:25 PM   #73
Billy Nees
Liked 7,682 Times in 1,730 Posts
You can use any rochester 2g carb with a 1.18 venturi size. Reread the first post in this thread and substitute 305 Chevy for 302 Ford. Don't waste your time putting in the subframe connectors. You don't need them and it's weight in the wrong place. your headers are probably too big but they're a good place to start.
Billy Nees 1188 STK, SS
Old 07-03-2011, 08:26 PM   #74
Liked 5,109 Times in 1,947 Posts
Dwight, you beat me to the keyboard this morning! I wanted to do the 304 (think spoiled brat stamping his feet)!
I'm going to guess that my next one could be done within our budget but I will probably have to go to Mark for a final thumbs up.
Lew Becker and I ran across one of these cars at an auction and I actually had Lew bidding on it. It was very clean and didn't go for any real money.
76 Buick Century with 2V 350/205 or put the 4V on it. It makes Q/R/T with 2V or swap intake and make O/P/Q.
1.250 Venturi 2g flows around 350 cfm, great heads, small cam, medium valves but at 205 HP it's 25 HP less than a 350 2V Chevy that does work.
Only real down side that I could see is the big, heavy body that it has to go in unless it were in a Skylark for P. But it is a 6 class car with an intake change!
Marky Mark, can it be under the index on our budget?
On this deal, I'd say, as fast as Bert Morgan goes, running under the index with a budget deal seems possible. We ran a second plus under the old indexes with a .060 over, Silva lite cast piston short block.
I wouldn't classify a 350 Buick V8 as a cheap or easy car to build though.
The oiling system needs some additional expense, that you wouldn't have with a SBC or Pontiac.
They have great torque potential but it doesn't seem to be very broad. You can't hardly shift out of 1st gear soon enough. Remember, they have the same stroke as a 460 Ford
I think you would want the heaviest combo there is , index wise.
I don't know about the 2 bbl...Not in this part of the world.
Old 07-03-2011, 08:32 PM   #75
The fenders and hood are the same till 81 (Formula). The nose piece is different, as is the rear fascia and bumper cover. License plate is between the taillights 77-78
Old 07-04-2011, 07:54 AM   #76
goinbroke2
Liked 380 Times in 147 Posts
I LOVE this thread! Had/lost a 82GT intake damn it. Been looking ever since. I'm a little leary on 86 fuelie 302's though as that was an "oddball" year with unique flat top pistons and bad flowing heads with "swirl dams" built in. The 87 and later fuelie 302's obviously work much better.
That said 162hp 2bbl 302 or 200hp fuelie;
162 hp, .419/.448 lift, hyd cam, 67cc head, 1.21 carb (I think)
200hp, .445/.445 lift, roller cam, 62cc head, 2.3" throttle
Is the roller cam, more lift, smaller chamber and higher flowing intake side worth 38hp???
Other note I guess is I like the look of the 82 but not the 86 LOL!
Old 07-04-2011, 08:21 AM   #77
goinbroke2
Oh, can I add one please? 91 ranger 2.3 4cyl auto.
Not a killer as it's heavy for JT/SA but....
2.3 @ 105hp
10:1 comp 57cc head
1.73/1.5 valves
.254 lift (ohc)
25.86 factor making it 2715 lb's where JT/SA is 22.0 and over.
The 2.3 ford has a HUGE fan base/knowledge in roundy round and rally trucks and 4cyl rangers are given away with a box of strawberries around here.
Index of 16.75...thoughts?
Old 07-04-2011, 08:40 AM   #78
Billy Nees
Happy July 4th! One more "popper"!
77-83 Mopar 2V 225/140
This is probably the "Dime Rocket" with the most pop for the dime but you gotta like slow, not pretty (IMHO) cars.
Small Carter 2V carb beats any other inline 6 (except AMCs).
.410/.419 cam
6 real intake ports (that ain't bad) and the manifold is better than it looks.
Valves are small but not too small for the cylinder.
Long stroke and not alot of compression but hey, 140 HP with 2v carb.
Bodies are still plentiful as are rears and engines for not alot of $$$.
Low gear 6 cyl case 904s can be found.
Early no frills Volare could be made light enough to fit U. It seems like all of the other bodies would have to lose wt. to fit V.
Might have to "copple up" some truck headers but they're around.
Good scrounge could do this one really cheap!
Old 07-04-2011, 08:43 AM   #79
Billy Nees
2.3 @ 105hp
10:1 comp 57cc head
1.73/1.5 valves
.254 lift (ohc)
Or run NHRA W/SA @ 24 lbs. Now it ain't so heavy.
Old 07-04-2011, 09:24 AM   #80
The Hawk
The Hawk's Avatar
Liked 249 Times in 109 Posts
.410/.419 cam
There`s one of these out of Nebraska that just recently went nearly one second under the new index/altitude factor in Denver a few weeks ago. That`s 1.48 under the old index in V/SA!
Lane Weber
