Old 01-01-2021, 11:48 AM   #61
monte8616
Liked 14 Times in 6 Posts
Default Re: LOST 10mph AND ABOUT 6 TENTHS
Originally Posted by Stan Weiss View Post
Is the car down everywhere in the run or is the early part of the run still about the same?
Stan
Everywhere
monte8616 is offline   Reply With Quote
Old 01-01-2021, 01:19 PM   #62
FED 387
Liked 333 Times in 180 Posts
Try disconnecting the fuel line at the rear of the car blow it out with a low pressure air hose ---if you have a filter blow the line between rear of car and front of filter make sure its open ---then try from tank to before the filter with line disconnected--- from the rear to front try blowing from tank side of the filter thru the filter --- probably a clogged filter --if you do the 3 step method you will isolate where its "plugged"--- how old are the fuel lines in the car?? are they Aeroquip??? or stock??? if they are more than 2-3 years old might be time to replace them as the lining has maybe deteriorated -also check regulator for any obstructions ----FED 387
Old 01-02-2021, 12:29 PM   #63
Capri
Liked 27 Times in 14 Posts
For curiositys sake, did you check the rear end housing and see if its flipping? We straightened out a pinion angle shifting problem and housing binding on a car and it was worth half a second.
Capri is offline   Reply With Quote
Old 04-21-2021, 09:49 AM   #64
greg h williams
Liked 23 Times in 4 Posts
Does anybody know if this problem was ever resolved? Curious as to what it ended up being.
greg h williams is offline   Reply With Quote
Old 04-21-2021, 12:38 PM   #65
Angelo DiTocco
Angelo DiTocco's Avatar
Liked 189 Times in 48 Posts
Definitely Check all your battery cables and grounds etc... carefully!
Angelo DiTocco
'98 Firebird SS/HA
'98 Firebird B/SA
Angelo DiTocco is offline   Reply With Quote
Old 05-02-2021, 02:51 PM   #66
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
With a Data Logger, on my car I was able to take my best run and just superimpose one run over the other....
Look at flash, fall back, EGT, fuel pressure and all of your data inputs.
My old AutoMeter logger had this feature, but I don’t know about racepak
Good luck
Bob Mulry 7516 STK
A & M Motorsports
Old 06-07-2021, 10:53 PM   #67
monte8616
Just in case anyone would like an update... it appears as though the electric fan we changed to must’ve been the issue... we went to a water pump/electric fan combo and car ran well - still a few kinks to work out but it appears as though the gremlins have moved on!! Thanks so much for all the ideas and advice!!
Old 06-13-2021, 02:20 PM   #68
The Hawk
The Hawk's Avatar
Liked 249 Times in 109 Posts
Glad you figured it out!
Lane Weber
