#61 |
Liked 780 Times in 194 Posts
Billy -
The Buick is on my list, too! If you consider the 4-bbl version at 240, the same spec engine is listed for 76-79 which gives more options. |
#62 | |
Liked 2 Times in 2 Posts
If I read this right, a 79 Firebird with a shipping weight of 3358 LBS would have a weight break of 18.66 and fall into R/SA. The index is 14.05 ?
Tod Lane Swartz & Lane 66 Nova Swartz & Lane 79 H/CM Trans Am |
#63 |
Liked 2,741 Times in 967 Posts
This thread is what class racing is all about. Way cool.
#64 | |
I'll get back on the Buick. I have to look at some specs. First problem is a cheap set of headers... Second is finding a torque plate....
#65 |
'78 Firebird Formula has a 19.18 break, so it is a natural T car and will fit U with weight.
#66 |
Liked 574 Times in 212 Posts
Jeep Comanche (pick up) with 4.0 inline 6 and fuel injection (1990 I think) fits P-Q-R. I think someone has one on the east coast. Cheap parts. Since many of the Cherokees (same frame) are used to "off road" race in the Southwest deserts so parts are plentuful.
#67 |
Isn`t there a trick similar to this with the oil ring?
Lane Weber It`s Not What You Drive That Wins....It`s How You Drive It |
#68 | |
What about the regular 4dr late 90's Cherokee?? Does it fit??
Nautilus Racing |
#69 |
Yes, Lane. You can use under size (std, .020 bore ,etc) expanders .
Or you can squeeze each ridge with needle nose pliers and then drag the piston through the cylinder with a fish scale and see what you've got... Or, 3 Open up the wallet and call Total Seal, Gregg Luneack or someone else that's competent.
#70 |
Cherokees are not in the Class Guide. Grand Cherokees are starting in 1996. The 1999 Grand Cherokee and the 2001 and up Dakotas with the 287 (4.7 V8) are also a good choice, just don't believe that motor can be raced for cheap.
