Old 10-12-2013, 02:37 PM   #51
Wade Mahaffey
Wade Mahaffey's Avatar
Liked 18 Times in 8 Posts
Default Re: 58 Corvette RACEtoration is back online!
Got my wheelie bars all welded up today. I use the S&W standard 48" bars, then I cut and modify several portions to better fit the Corvette. The nine inch rear already had brackets in place on the rear. I welded up all of the housing components prior to narrowing and welding the ends on last. Now that they are welded up and fit perfect, I will disassemble, box them up....and off to chrome!
Wade Mahaffey
Wade Mahaffey is offline   Reply With Quote
Old 10-21-2013, 01:37 PM   #52
Wade Mahaffey
I've been working in the rear of the car. When I had put the car on the ground, it seemed a little high in the back with the new leaf springs. I know a lot of weight still has to be put in the car as it's just a shell. But I removed two of the four leafs from each side
I made provisions for maximum wheelie bar clearance. I notched the rear frame cross member and welded in material for a nice finish. The modification allows the wheelie bars to travel higher, but stop prior to hitting the cars body
Old 10-21-2013, 01:59 PM   #53
JP
JP's Avatar
Awesome job!
JP is offline   Reply With Quote
Old 10-21-2013, 06:48 PM   #54
cicero819
cicero819's Avatar
Liked 69 Times in 30 Posts
Wade, forget the chrome just clear coat them, raw metal is cool also.lol Looking good keep up the great work. Claude Ruel
Old 10-21-2013, 07:37 PM   #55
Wade Mahaffey
Raw is cool, but chrome is my favorite color....especially when it lays on top of red! That combination cannot be beat on Race Cars, Hot Rods and Fire Trucks. LOL Actually Chrome is clear, the nickel is the silver and usually over copper base. Each step polished to a high luster
Wade Mahaffey
Old 10-22-2013, 12:21 AM   #56
Geerhead55
Liked 5 Times in 5 Posts
Wink Re: 58 Corvette RACEtoration is back online!
Wade,,, I've enjoyed following this build. I don't get east very often, so I wonder if you plan on having the car at Columbus next May for the Northern Class Nationals? I'm looking forward to seeing a lot of the cars and meeting the people that are on here at the event.
Keep up the good work,,, and I'm wondering if you'll need to put a 3rd leaf back in once the car settles.
Danny Durham
Old 10-22-2013, 07:18 AM   #57
Wade Mahaffey
It is certainly possible that I may have to add a leaf back into the mix. And maybe not even the normally next leaf, but maybe the #4 shorter leaf. There are several combinations of leaf springs arrangement, that will provide adjustable advantage. That, supported with (Strange Engineering) external adjustable shocks should allow me to tailor the rear suspension to the desired static and dynamic performance conditions.
I would like to support Michael's Northern Class Nationals event with the car.
Wade Mahaffey
Old 10-22-2013, 11:42 PM   #58
Geerhead55
Thumbs up Re: 58 Corvette RACEtoration is back online!
I'll make a point to drop by and see you there, Wade. Take care.
Danny Durham
Old 05-12-2015, 08:09 PM   #59
Frank Castros
Liked 2,738 Times in 965 Posts
Wade,
What's new with the Vette?
Old 05-23-2015, 10:18 PM   #60
Wade Mahaffey
I gotta spray the under side Red, then put it back on the frame. Once I do that I can tie the cage into the chassis. Then I can start making the cool stuff...the real cool stuff! I'll be back on it soon
Wade Mahaffey
