Old 05-03-2020, 10:45 AM   #41
Stan Weiss
Stan Weiss's Avatar
Liked 735 Times in 386 Posts
Default Re: stock class rear axle?
Originally Posted by Dissident View Post
Jeeps also used Dana 44 drive axle differentials.....I think AMC also used them. Chrysler owns Jeep....You do the politics.
Regards,
HB2
Dissident
Not sure where this round able for Chrysler is going. But they used Dana 60's in some production cars.
Stan
Old 05-03-2020, 11:28 AM   #42
Alan Nyhus
Liked 800 Times in 237 Posts
Well, I stand corrected.
Billy, many years ago I parted out one of these cars for the engine. I didn't want to let the shell go with the Spicer rear in it but a hard hit on the rt. rear had tweaked the caliper and rotor and I figured the axle tube was wonky. In retrospect, I should have pulled the rear end.
"That'll never work....."
Old 05-03-2020, 12:30 PM   #43
Ed Wright
Ed Wright's Avatar
Originally Posted by XSTOCKER View Post
The Olds/Pontiac rear is not acceptable for a Stocker trifive......I asked.
That is silly. A ‘57 Pontiac is a bolt-in deal. Only driveshaft shorter, with larger U-joint on the back. Not faster, just less breakage. I ran a ‘56 Chevy 9 passenger wagon in MP, before ever running Stock. The Olds rears needed some work. They came with coil springs in the back.
When I made the wagon a Jr Stocker, I ran the Pontiac rear, not one Tech guy ever noticed. When I went to the sedan the next year, I kept the Chevy rear end. Not nearly as nervous if a Tech guy looked under it. Pontiac rear could be no faster, just more heavier, and less starting line breakage. They looked much alike from the back, Pontiac was a little larger. For a whole season, nobody noticed.
Ed Wright 4156 SS/JA
Old 05-05-2020, 05:25 PM   #44
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
You guys got me thinking.....
I have a state of the art Chevy Drop Out Center Section with maybe a 5.38 gear
Henry's Axles, MOPAR spline with heat treated Stahl-Moroso side gears,
Steel carrier bearing cap, alternate Posi Plate stack and the back of the housing has a tension bolt to pre-load the cap.
State of the art in 1965...
Bob Mulry 7516 STK
A & M Motorsports
Old 05-09-2020, 03:40 PM   #45
Bernhard
Are aftermarket 12 Chevy diffs legal in stock and super stock?
The 68/69 Cutlass and 442 built in Canada had a 12 Chevy diff.
Aftermarket diff link
https://www.markwilliams.com/gm-12-bolt-housings.html
Bernhard is offline   Reply With Quote
