Old 04-03-2014, 01:45 PM   #41
Run to Rund
Liked 54 Times in 27 Posts
Default Re: Ordering New Transmission, but What Gears ?
I believe Jerico has discontinued the DR4 and only offer the DR4-4 now. Also they no longer offer the top and bottom cover cases. When I got my DR4 in 2007, Scott did not feel there was any reason for me to get the -4 at my power level, but he did recommend the high quality aluminum top loader case that I believe is now standard. He said that the GM 26 spline input is a bit stronger than the 18 splline hemi input, and the input nose is .25" longer than stock to fit the pilot bearing better with the bellhousing's block plate.
Old 04-03-2014, 01:56 PM   #42
Sean Marconette
Sean Marconette's Avatar
Liked 274 Times in 76 Posts
X3 on the G-Force. Split case design and changing gears are a piece of cake. Make sure you get it setup to read input shaft RPM no matter what trans.
FWIW,
G-Force also sells reconditioned transmissions. They are not as expensive and you pick your gear ratios. If something is worn, it is replaced.
If you get a Jerico they have a much better deal with an input shaft sensor being internal. Otherwise it's a magnet inserted into the input shaft and the sensor mounts to the candlestick. Setting the clutch and seeing what and how the clutch is responding cuts down on the seat of the pants trial and error. So if you do not already have a data acquisition system it's money well spent.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 04-03-2014, 02:38 PM   #43
terry1
Liked 24 Times in 13 Posts
I didn't realize that the DR4-Rev 4 was that much more $ than the original DR4,WOW!
terry1 is offline   Reply With Quote
Old 04-03-2014, 10:35 PM   #44
Aubrey N Bruneau
Aubrey N Bruneau's Avatar
Liked 7 Times in 3 Posts
Send a message via Yahoo to Aubrey N Bruneau
Oh yeah, the new DR4 rev 4 ( or whatever the heck they're calling it ! ), will break the bank now.
Yes, better look at G Force as well.
I have no data logging system as of yet.
Aubrey N Bruneau 6409 C/S
62 BelAir sport coupe, 409 HP 409
Aubrey N Bruneau is offline   Reply With Quote
Old 04-03-2014, 11:10 PM   #45
Stephen & Horace Johnson
Liked 161 Times in 52 Posts
you are correct, you cant get the dr4 anymore..only the Rev 4
Stephen Johnson #2162
Horace Johnson #2167
Stephen & Horace Johnson is offline   Reply With Quote
Old 04-03-2014, 11:13 PM   #46
bigsixman
Liked 2 Times in 2 Posts
I do not know if something has changed, but Scott told me back in 1997 when I purchased mine, the 18 spline hemi imput was stronger.
1969 camaro, pump gas 540"bbc, jerico
1967 camaro, pump gas efi 620", coan t-400
bigsixman is offline   Reply With Quote
Old 04-03-2014, 11:53 PM   #47
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
I just went through all this. I was quoted 4400.00 for a G101a G Force with shifter. So that's what your looking at with them. That was a reman not new. I got a CL4-4 Clutchless but I run SS. These things have gotten out of hand on price. Good luck.
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 06-22-2014, 12:58 PM   #48
Aubrey N Bruneau
Talking Re: Ordering New Transmission, but What Gears ?
Well.. I didn't get the transmission ordered on time for Mission Instead, went on the big European cruise ship, and another 7 days in Italy. hey... wasn't so bad:
( in Venice, view from the dock at our hotel )
Also, I got the first batch of my single plane 4 barrel 348/409 intakes machined and shipped !
So, I'm finally ordering my new Jerico this week. Looks like I'll go with the 3.19 first gear, running with the theory that I can launch at a lower RPM, and use the engine and the light flywheel to accelerate the car.
Thank you again, for all the help
ID:	24433   Click image for larger version
Old 06-22-2014, 01:21 PM   #49
Adger Smith
Liked 880 Times in 311 Posts
Nice looking intakes!
I think you made the right choice on gear. It will offer you more options as to adaptability. You can jack it up or down & even go overboard on a track with teeth!! It also has some good points with clutch adjustment. It also offers a better % of drop between gears to take advantage of you engines capabilities. Good luck.
Ed, have you priced or bought a new Proflite, Coan or any other name tranny. Not cheap either!
Adger Smith (Former SS)
Old 06-22-2014, 01:22 PM   #50
Peter Ash
Peter Ash's Avatar
Aubrey
You may still be able to make it to Mission.
There are delays and event rescheduling as BCCCA deals with the technical issues of the track resurfacing.
https://www.facebook.com/#!/pages/Mi...k/311453515978
Peter Ash 6100 STK
Peter Ash is offline   Reply With Quote
