06-24-2018, 04:51 PM | #451 |
Liked 1,958 Times in 493 Posts
Re: H-I-J '76 Nova re-fit.
Thank you Glenn, I appreciate it.
Todd Greene |
06-24-2018, 05:44 PM | #452 |
Liked 323 Times in 119 Posts
This is to charge the battery in the pits?
06-24-2018, 06:33 PM | #453 |
Todd Greene |
06-24-2018, 06:49 PM | #454 |
Liked 162 Times in 45 Posts
I am looking at all these battery cables in the engine compartment and wondering what the heck is going on here. Why can't we charge the battery without the charging lugs? Why can't we disconnect the battery at the battery without the battery switch? The KISS theory was not used here. When this car rolls across the scales little thi gas like this will all add up, quickly. And the more connections there are, the more possibilities there are for loose connections. But what do I know?
06-24-2018, 07:06 PM | #455 |
06-24-2018, 07:13 PM | #456 |
It's the gauge light switch.
Todd Greene |
06-24-2018, 07:18 PM | #457 |
06-24-2018, 07:39 PM | #458 | |
The charging lugs you say, well here's the deal, I never owned a car that needed the battery charged, so off we go to the track, drag out a battery charger and stretch it across my pit to charge the damn battery. Well I trip over the cord twice and I got pissed off, so now guess what... I keep my charger and the cords next to the trailer so I still don't have to pick up my feet when I walk... Aaand the battery still gets charged, just my way of doing it. Plus my wife said I can't spend over $500 per week on the car, and if I don't spend it every week where will I be when I have to appeal to the budget committee for an annual increase? I just made that up, I can spend as much as I want!
Todd Greene |
06-24-2018, 08:35 PM | #459 |
Liked 300 Times in 160 Posts
coupla suggestions here that might make life simpler---First put a volt meter in at the battery---if it gets below a certain level time to recharge the battery that way you can see exactly how much charge is in the battery at all times ---second for charging I took my battery charger and replaced the alligator clips with a 50 amp Anderson connector then fabricated a small bracket and installed another Anderson connector with 10 Gauge wire running to the battery posts---you cannot screw up hooking the charger to the battery its just plug it in AND correct polarity every time-- now you can make that cable from the charger to the battery any length you want ONLY one wire going from the charger to the car, no tripping over extension cords, battery cords or the power cord for the charger ---easy, inexpensive and it works --FED 387
06-24-2018, 08:54 PM | #460 | |
Todd Greene |
