Old 05-20-2020, 07:11 AM   #391
Liked 10,931 Times in 2,258 Posts
Default Re: Dumbo The Flying Elephant
I got a few wires uncrossed and stuff started to work. Loading up today for testing tomorrow. I hope the changes will improve the car.
The down side of a new metric / standard car is the addition of the extra tools in the trailer. Don't forget the VO Meter, test light, soldering gun and rosin core solder, connectors, and picks. And the most important tool, the wiring diagram.
I think I'm ready
Old 05-20-2020, 09:48 PM   #392
Keith Bennett
Keith Bennett's Avatar
Liked 70 Times in 36 Posts
Send a message via MSN to Keith Bennett
Good luck to you sir.
Keith A/S 2990/Terri A/SA 2991
"Imagine what you'd attempt, if you knew you could not fail!"
Keith Bennett is offline   Reply With Quote
Old 05-21-2020, 05:52 AM   #393
Since everything was falling into place and I was ahead of my timeline, checking the valve lash was a great idea. Working on the Hemi on the dyno is fun, in the car, as Dan would say, not so much. I only had to adjust two valves .001- .002 loose. It only took a quick 180 minutes plus, a half of a box of bandaids and every tool in the box and then some.
So now I'm up early tring to makeup for lost time. Back to work!
Thanks Keith
Old 05-21-2020, 07:30 AM   #394
J&S Racing
Liked 327 Times in 87 Posts
Pictures!!!!
Old 05-21-2020, 10:44 AM   #395
denbreeden
denbreeden's Avatar
Liked 67 Times in 27 Posts
I think I'm ready
Most important thing is a laptop, lol.
denbreeden is offline   Reply With Quote
Old 05-21-2020, 11:02 AM   #396
jmcarter
jmcarter's Avatar
Liked 3,232 Times in 983 Posts
I can definitely identify with the bandaids, young whippersnappers have no idea how thin your skin gets as you “mature”. I can hardly put gas in the car without bruising and/or bleeding. Swapping converters requires a transfusion....well, maybe not that bad but I definitely take a box of bandaids to the track and there’s a big box in the garage. Look forward to seeing the car soon, hope the testing goes well.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 05-27-2020, 06:43 AM   #397
Jim after being in business for years I'm pretty thick skinned, but old scar tissue is no match for razor sharp edges of plastic and steel. Testing this past weekend didn't go well.
Today is new and Dumbo is being fitted for new pipes, life is good.
Old 05-27-2020, 12:12 PM   #398
340Cuda
Liked 805 Times in 341 Posts
Larry,
Are you coming to Tulsa?
Bill Lamb
Old 05-28-2020, 01:48 PM   #399
Atlanta or Tulsa will depend on the weather. It will be a little farther to Tulsa from Ohio than Commerce Ga.
Old 05-30-2020, 11:26 AM   #400
340Cuda
Yes but in Tulsa you don't have to drive through Atlanta!
