Old 08-27-2024, 05:56 PM   #31
1700camaro
Liked 226 Times in 115 Posts
Default Re: Ppp shifter clean and relube?
When I get my car back from the body & paint shop. I'm inspecting the shifter, among many other things. If it needs cleaning & lube, it will get it.
I'm pretty sure
Mr. Keyboard KAREN 1320
will be along shortly!
1700camaro is offline   Reply With Quote
Old 08-27-2024, 06:29 PM   #32
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Paul, I do get exactly what I deserve, I worked for it, life is GREAT!
That said, my comments stand about your ridiculous thread asking about lube for a shifter mechanism.
Old 08-28-2024, 09:49 AM   #33
Signman
Liked 269 Times in 99 Posts
Originally Posted by 1320racer View Post
Wrong, I've made thousands of 2-3 shifts with my Turbo Action shifter in the Firebird without issues!
May not apply to you but did so for me and others
You're special though!
Old 08-28-2024, 09:54 AM   #34
1320racer
1320racer's Avatar
not special, just have motor skills and hand eye coordination to manually shift a 3 speed trans that you obviously don't.
Old 08-28-2024, 03:13 PM   #35
Jeff Stout
Liked 706 Times in 283 Posts
Foot brake that dragster? Not able to hit a tree even if it fell on you.
Old 08-29-2024, 10:00 AM   #36
Signman
LOL! You are very special...... Ground Strap....
Old 09-09-2024, 09:49 AM   #37
Signman
Originally Posted by Signman View Post
My PPP shifter has been acting up on the 1-2 shift going past 2nd so disassembled it either it needed maintenance or was worn out
The original lube was full of dirt cleaned it all off everywhere
Don't mess with the handle unless you have some patience.
Used Super Lube silicon grease as the assembly lube
Soaked the cable in trans fluid for a few days
Re installed making sure alignment and adjustment are as instructed.
Initially my impression was the spring that pushed the rod/disc up needed to slow down but with bench testing and in the car before and after the shift lever needed to speed up. That must be why PPP states most problems are in the cable.
Cleaning and lubrication worked as expected.
No more shifter issue.
Old 09-10-2024, 12:08 AM   #38
tuffxf
Liked 11 Times in 5 Posts
Smile Re: Ppp shifter clean and relube?
Mine turned out great also!
Cheers
tuffxf is offline   Reply With Quote
Old 09-11-2024, 04:04 AM   #39
Cglrcng
Cglrcng's Avatar
Liked 398 Times in 208 Posts
Originally Posted by Tex013 View Post
Paul ,
maybe try a teflon dry lube spray . I use a CRC Dry Glide from Repco , I use it on my hoists plus heim joints on the caltracs .
Tex
Same stuff really works on elect or hand cranked window regulators and seals also. Almost 40 years old and they now glide like new (saved replacing the motors...just cleaned out all that old dried up white lithium crud, sprayed all the tracks and seals, reinstalled them and like magic they glide up and down again). So, I also used it on the new shifter after installing it too!
Better than just new. Lol. Goes on wet, instantly dries, attracts less dust and dirt buildup.
Gary Lucier - 7832 STK. / 7832 E.T. EF/S Slow Sled. I am, but a simple test of your true patience. So, do all the really "Big Wheelies" you can!
Cglrcng is offline   Reply With Quote
