12-18-2022, 07:30 PM | #31 | |
Liked 6,966 Times in 1,570 Posts
Re: NHRA hp updates
Billy Nees 1188 STK, SS What is "NORMAL"??? |
12-21-2022, 02:51 PM | #32 | |
Liked 1,117 Times in 294 Posts
Re: NHRA hp updates
Your combo cannot affect anything other than that same engine combo. If your combo has different heads, valve sizes, etc, then it doesn't affect combos that don't have the same specs. So, if your combo has 2.07"/1.725" valves and oval port heads, it will not affect a combo with 2.195" and 1.725" valves and rectangle ports.
Alan Roehrich 212A G/S |
12-21-2022, 07:46 PM | #33 |
Liked 290 Times in 58 Posts
Re: NHRA hp updates
That's the way they say it works. For the 4.3 Chevy tbi engines they factor flat tappet cams, roller tappet cams, 108 wheelbase, 117 wheelbase, 430 lift cams, stock lift cams, cars or trucks together. All are considered the same engine family and body style.
Bob Shaw V/SA 515 |
12-21-2022, 10:43 PM | #34 | |
Liked 238 Times in 93 Posts
Re: NHRA hp updates
Would sure save me a lot of money im fixin to spend. Probably have 200 stockers at divisionals. |
12-21-2022, 10:53 PM | #35 |
Re: NHRA hp updates
Exactly!
12-22-2022, 02:16 AM | #36 | |
Liked 525 Times in 138 Posts
Re: NHRA hp updates
Mike 7570 A/SA |
12-23-2022, 10:49 PM | #37 |
Liked 225 Times in 104 Posts
Re: NHRA hp updates
They wouldn't do that. They paid a law firm to write the wording.
12-23-2022, 11:18 PM | #38 |
Re: NHRA hp updates
The FE engine family is confusing enough with all the different variations. There are numerous combinations that could be in the same class. Now I see how this could help with the average for each because hardly any two 428 cars are running the EXACT same combinations.
Mike 7570 A/SA |
12-28-2022, 04:04 PM | #39 |
Re: NHRA hp updates
What effect would bringing back the factory valve spring rule have?
Would this not simplify tech and negate some of the advantage found in cylinder head and intake advancement? |
