Old 11-14-2018, 09:28 AM   #31
Hacksaw
Liked 312 Times in 175 Posts
Default Re: Before I put this on
Originally Posted by Coleydog View Post
After reading all these post it got me thinking, would it be better to dump the tank oil back into the pan (with a one way check valve) so the pump could continue pumping from a steady supply? Or is it ok to dump into the pressure column since some volumn would be forced back at the pump even though its sucking air (more bubbles) at the time?
Mike
I doubt the can could supply enough volume quickly enough to keep the pump supplied with oil. Better to feed the pressure side.
Old 11-14-2018, 05:05 PM   #32
Liked 10,834 Times in 2,252 Posts
Have all the plumbing match the feed hole in the block, don't make a restriction with fittings or hoses that are to small. If necessary enlarge feed holes in block
Old 11-14-2018, 05:06 PM   #33
Coleydog
Liked 53 Times in 38 Posts
I see your point, thanks
Mike
