Old 06-21-2017, 10:02 PM   #31
BillK
Liked 30 Times in 17 Posts
Default Re: cometic head gaskets
Originally Posted by Jeff Stout View Post
On my sbc I didn't spray coating as I was informed by many not to. If you had good luck spraying then I will on next rebuild for piece of mind as I run alot of nitrous and feel leary of not coating them. Thanks for the info.
You have to be careful with this as most MLS gaskets have a coating on them from the manufacturer that is there to help them seal. Putting another coating on them might actually make it worse. I prefer to go with whatever the gasket manufacturer recommends.
Bill Koustenis
BillK is offline   Reply With Quote
Old 06-21-2017, 10:23 PM   #32
carl hinkson
Liked 18 Times in 10 Posts
Jeff
I have always sprayed my Cometic head gaskets with Copper head gasket spray with no problems to date.
I have seen quite a few old Cup engines that have used cometic gaskets that were sprayed with Copper head gasket spray. If they are using it that's good enough for me.
carl hinkson is offline   Reply With Quote
Old 06-22-2017, 08:08 AM   #33
terry1
Liked 24 Times in 13 Posts
Smile Re: cometic head gaskets
Rick, are you going to be ready for the Miramichi NHRA races???
Terry K
terry1 is offline   Reply With Quote
Old 06-22-2017, 01:04 PM   #34
RonP
Liked 29 Times in 14 Posts
OEM head gaskets require a "smoother" surface finish to seal coolant and oil passages. The "rubbery paint" is there to provide a micro-seal against leaks. OEM head gaskets are beaded to provide an effective sealing load around these passages and the chamber.
A torque wrench measures torque, not friction as someone stated earlier.
Torque = friction coefficient x tension x thread diameter (for elastic region bolts).
Friction coefficient is generally 0.1 ~ 0.3.
Adding oil or other lubricant will increase the bolt tension over a dry or unlubricated condition. Something a friend and I did at work years ago with a strain gauged bolt to see for ourselves.
RonP is offline   Reply With Quote
Old 06-22-2017, 03:25 PM   #35
SSDiv6
In lieu of the Copper head gasket spray I would recommend Hylomar spray.
Do not use the Permatex/Loctite Hylomar sold at most auto stores; it's a watered down version of Hylomar.
The best Hylomar is the Yellow can industrial version.
Old 06-22-2017, 03:42 PM   #36
BillK
Ron,
That is correct and what I was trying to get at was the fact that the friction will significantly affect the preload on the fastener for a given torque. My choice of words were not the best
Bill Koustenis
Old 06-22-2017, 08:22 PM   #37
Rich Biebel
Rich Biebel's Avatar
Liked 557 Times in 217 Posts
I have used Cometics with zero issues for at least 5 years. I have reused the same gaskets 3 times with no additional coatings and also another set 2 times with copper coat spray. This is a 15-1 compression engine and with or without the copper coat there was no leaks. Pretty smooth finished block and heads. I generally block sand the heads if they are off with wet 400 paper in a wash tank. Cometics work very well for me.
Rich Biebel
S/C 1479
Stock 147R
Old 06-22-2017, 10:18 PM   #38
RICK W
Thanks for all your comments guys, the block is just machined too rough for those gaskets
RICK W is offline   Reply With Quote
Old 06-23-2017, 02:18 PM   #39
Ed Wright
Ed Wright's Avatar
Listen to Rich.
Ed Wright 4156 SS/JA
Old 07-05-2017, 08:29 PM   #40
Greg West
Liked 52 Times in 22 Posts
Something else to consider on a SBC is the size of the dowel pins. The OE dowel pins are .309" diameter. If .3125" (5/16") pins are used the head can bind on the pins. This will prevent the head from clamping properly to the block in the lower corners. Several companies sell SB dowel pins that are actually 5/16" roll pins.
Greg West is offline   Reply With Quote
